I don't. But I have vice grips.Do you have a dowel pin remover?
This^^^^Do you have a dowel pin remover?
Some are the slide hammer type, but I have the type uses a threaded rod to tighten the tool to the pin.
I can send you the parts you need (to minimize shipping) if you need, but it might take some time to get them. Better if you can borrow or rent some if you don't have the right tool.
<Edit>
I found some old pictures showing it's use in case this is useful for anyone.
Get the right size first and slip it on the pin
Then insert the tightening sleeve and the threaded shaft.
Put the pulling sleeve over the assembly and tighten...
...and the pin comes out.
The offset dowel can be turned (wrench) and tightened using the Allen set screw
Hope this is helpful for any members who may not be familiar.![]()
See, if you were my neighbor, I would be asking to borrow that cool tool. Never saw one of those before.Do you have a dowel pin remover?
<Edit>
Notice how Hawk has all the cool tools. It's like he knows an engine builder or something.See, if you were my neighbor, I would be asking to borrow that cool tool. Never saw one of those before.
I don't. But I have vice grips.![]()
Absolutely those methods usually work too! You just can't use them again (although it is doubtful you will need them again).Or weld a lug nut onto the dowel and crank it out.
That is what I did.
Haha. I wish I had all the cool tools! But it is nice to be able to (temporarily) steal all the cool, expensive, specialty tools I need!Notice how Hawk has all the cool tools. It's like he knows an engine builder or something.
Very true. This should not be the next project for someone who just learned to change their spark plugs. However it's this site that gives shade-tree hobbyists like myself the confidence (maybe misguided) to tackle these harder projects. And the good members here that will weigh in and help out if and when you get into a bind.This thread, like Gregs, is a prime example that updates like transmissions are not for the faint of heart. I can't even begin to imagine the tech calls they must field daily. All the more reason to have more thorough and better instructions. Could you imagine how something like this job could be to do for someone who has a hard time changing oil?
Yeah, its a long shot no doubt. But I'll clean it off, wire brush it, etc. just to remove each variable.Paint on the machined block surface will cause runout on the face of the bell housing but your not measuring the runout on the face.... Your measuring runout on the bore... I seriously doubt there's enough paint on the block surface to effect the bore runout much....
You mean a .010 variation in the block to bell mating surfaces? A variation of that magnitude wouldn't be caused by paint, right?Paint on the machined block surface will cause runout on the face of the bell housing but your not measuring the runout on the face.... Your measuring runout on the bore... I seriously doubt there's enough paint on the block surface to effect the bore runout much....
Distance effects the error... So the fact the bell housing bolts to the block probably 7" from the bore your sweeping means a minor misalignment is amplified...
But to counter that effect if the bolts mounting the bellhousing were on a 3" circle a .010 variation at 7" would probably be .070.... But the bellhousing bolt circle is around 15-16" so a .010 variation of the surface would probably only register .004-.006 on the bore...
I could try that. But it would only be around a 270° sweep because the bottom is open.While looking at runout do they have you sweep the trans mounting surface? The factory manual does... Just move the dial indicator stem from the bore to the mounting face...
The indicator base is attached to the center of the flywheel, between the bolts. It rotates in such a tight circle, if there was runout would it even be picked up by the indicator? And we removed the base and repositioned it when we switched dial indicators, and the high point was again at 2:00.Another thing to check is runout of the flywheel face...
Right.And BTW if they tell you they've never seen this before I refer you back to post 25...
Right. We're not making offset dowels or hogging out bolt holes to make this work. If it comes down to it, SST is shipping out another bell.If cleaning the back of the block makes no difference to the runout numbers, the fix for that is still undetermined. I don't have the ability to make offset dowels. Being off by .080 means the bell has to shift .040 to be centered. Look at the .035 gap in a spark plug. The offset is bigger than that. This leaves 2 options: Custom dowels or the vendor sending out another bellhousing. For the money these kits cost, I'd sure expect SST to back up their products and send out another BH. The custom dowels with that much offset would require ALL the mounting holes in the bell to be ovalled out. This is obviously not ideal.
If we can't knock the TIR down to a manageable number, then SST needs to stand behind their product. I'll ship the bell back and have them check the TIR at their shop.If the OP was piecing together a swap from a variety of different suppliers, he should expect to run into some conflicts since all the different vendors may not communicate to each other to make the parts work together. This setup all came from one supplier. They should know what fits, what doesn't.
When I swapped the Tremec in my car, I had paint on the block.
I read the thread. The tool doesn't measure how much the BH is offset, you shine a light in the gap and make an educated guess. SST (and American Powertrain for that matter) has some pretty specific instructions on how they want the runout documented. Before investing in this tool I would talk to them first.What about this Browell tool here that Bio used?
Browell Bellhousing Runout and alignment kit. 100% reliable
If I ever finally do a manual conversion I think I'd get one as this step in the conversion is the one that worries me the most.
Maybe you could sell it after you're done?
I thought the tool used the light just to determine in which direction the alignment was out and which direction it needed correcting. Once it was aligned you wouldn't see any light. I could be wrong though...I read the thread. The tool doesn't measure how much the BH is offset, you shine a light in the gap and make an educated guess. SST (and American Powertrain for that matter) has some pretty specific instructions on how they want the runout documented. Before investing in this tool I would talk to them first.
Autos need to be pretty close too...The block has a 1976 casting date. What if Chrysler wasn't as concerned with precision since they weren't fitting any manual transmissions behind 440s after 1975?
It could be but the painter would have to drink a few Kamikazes before picking up the gun..You mean a .010 variation in the block to bell mating surfaces? A variation of that magnitude wouldn't be caused by paint, right?
I'm now sure where you plan to measure but I'm talking about the back face of the bellhousing where the trans mounts... Like this...I could try that. But it would only be around a 270° sweep because the bottom is open.
To measure runout of the flywheel you would reposition the dial indicator so it is mounted to the block with the stem touching the clutch face of the flywheel then rotate the engine to see if the flywheel runs true or has runout.... It shouldn't..The indicator base is attached to the center of the flywheel, between the bolts. It rotates in such a tight circle, if there was runout would it even be picked up by the indicator? And we removed the base and repositioned it when we switched dial indicators, and the high point was again at 2:00.
On the subject of tools, Greg fabb'd a handy flywheel dowel on a moments notice. Took an extra flywheel bolt from his stash, ground down the head, cut a groove in the top for a screwdriver to back it out once the flywheel was in. Much easier to start the bolts without having to hold up the flywheel.Absolutely those methods usually work too! You just can't use them again (although it is doubtful you will need them again).
Haha. I wish I had all the cool tools! But it is nice to be able to (temporarily) steal all the cool, expensive, specialty tools I need!![]()
