Vacuum advance w/ solenoid
Forgot yes chry did make a turd
Lean Burn anyone have the pleasure of working on one?
I had a Cordoba '75 or maybe was a '76 that had that 'command center' mounted to the air cleaner if my memory serves. I had one problem after the other and come to find it needed replacing and at a high price. I got lucky yanking one from a boneyard...
My 70 Charger RT is from California, they also added more garbage to the kill the performance package. It included conversion to unleaded, al large spring was inserted in the filler neck , carb was changed to a Holley , a sticker was placed on the dash advising to drive slower for better fuel economy etc. They did finally toss the points Distrubutor and went electronic till I bought it now I’ve removed most and went back part number date code on all.
Old post ,will the distributer work with the single wire disconnected like a normal one ,the can gets really hot with the wire hooked up running
