The circuit breaker resets automatically....
The circuit breaker is closer to the interior end of the wiring than the battery end. It could not be installed near the battery without cutting the wires or hogging a 1 1/4" hole in the firewall and using a huge grommet.The circuit breaker needs to be located at the battery to protect the wires if there is a short.
Classic Auto Air sources power from a 20 amp circuit so it is protected. Vintage sources from the battery.The Classic Auto Air setup wasn't like this.
Will this panel above the steering column come out and have room for this switch unit?An oval hole would have to be cut into it OR maybe 3 smaller shaft holes...Dwayne didn’t like the design or functionality of the control panel that VA usually includes in the 1968 B body kit. He heard of reliability issues so he went another way.
This is a nice looking unit.
I looked on the Vintage Air site last night. This looks like one they offer as replacement for a Ford truck from the 60s. It isn’t cheap…todays cost is around $250.
Since it is meant as an OEM fit for something with a flat dash panel:
The back facing screws look like they tighten against the back side of something.
I have to figure some way to mount this. I mentioned this issue a month or more ago. Since then, I’ve had zero ideas on what to use. Dwayne wats it on the lower section of the dash near his right knee. For that I’d need some type of 90 degree bracket.
I am OPEN to suggestions here.
It would be a direct bolt in with no fabrication. Dwayne actually has it at his place, he seems to want the knob design. I'll admit, the Ford one does look nice.I don't know why you aren't using the panel VA supplies.... Easy, clean, & they work
Not sure, but I think you have the apron side j-bolt in the wrong upper hole. Try the other one for better alignment? I might be wrong.Under hood wiring is done, battery is back in.
Backing up a bit…
The battery hold down cross bar is held down by two J bolts. The one on the engine side is easy. The one to the fender apron is shorter but now I have the #8 hard line taking up some space. This battery seems slightly wider than others. It has a sleeve around it too. I slipped a rubber vacuum hose over the J bolt that attaches to the fender.
It is tight.
I put a slight zig zag in the bolt.
I couldn’t risk the J bolt sawing through the hard line after vibration.
Similar reason I didn't order their condenser and went with a larger unit. I was advised by another well respected classic mopar owner friend as well as several shops to install the biggest condenser that would fit in front of the radiator for maximum cooling. I've read that sometimes people with larger cabins like our b-bodies complain about inadequate cooling with the stock condenser as compared to smaller cabin classics like a pickup truck.I don't know why you aren't using the panel VA supplies.... Easy, clean, & they work
elegance and beauty? Are we talking about the same automotive dash? I've always thought it looked spartan and not that great. Have wished for a rally round gauge arrangement like the Dodge R/T's, but then again, those are not easy to read.That ford panel does look nice, but it honestly looks like a snazzied up mini van control panel. I don’t see any good place to put that control panel other than in the glove box which would be completely inconvenient.
These cars were built with such elegance and beauty, everything was put in a place with care and attention to detail. The factory control panel and it’s placement is dare I say perfec
