What a work out!!!!! I'll be swore from that night for sure, had a little trouble getting the tranny in and with me being the jack that was holding it forever my arms feel like butter. I put the tranny in the first time pretty easily but couldn't get the last 1/2" to close up so I pulled it out to double check the pilot bearing and clutch disc seating depth (everything was spot on). Not able to find anything wrong I tried again but this time for whatever reason it took forever to get it engaged but once I did it wiggled all the way on without forcing anything. I'm wondering if the pilot bearing had enough grease on it to create a hydraulic effect not allowing the input shaft to push the air out?????? The tranny is
DONE, I still need a driveshaft, rear yoke and to install the complete M.C. setup but the tranny is
DONE (I hope).
Change of plans on the T.O. spacer, I was going to make a 1/4" thick one to bring it to 1/8" clearance but after looking at the T.O. I changed my mind. In the pic you can see the raised boss on the tranny that centers the T.O. so the input shaft doesn't rub in the bore and then the recess in the T.O. that fits over that, there's the reason for the change. The recess is only .200 deep so by the time you make a .25 spacer and machine the centering bore in the back you'll nearly cut the lip off so I chose to make an 1/8" spacer leaving .075 of the recess to center it and putting me at the .250" maximum limit (by McLeods recommendations).
Here's the special fitting from Summit to adapt the T.O. to a 3AN fitting, just drive the roll pin out and swap the fittings. The hose was only about $20.00 from Summit (24" 3AN).
Do not, do not, do not, do not forget to put this in!!!!!!!!!!! I bought a used TKO before this one and had a nasty starter noise and now I know why, this bushing goes in the top starter hole to bush it to a 3/8" bolt and didn't come with the parts for the TKO and of coarse the starter being hidden in the headers I didn't catch it. This was one of my worries was that starter noise so I feel better now knowing why it did it.
Here's the skip shift solenoid or what's left of it, I just threw it in the lathe, turned the end off and welded the hole shut, now it's just a plug.
The final product, finished beefing up the tranny mount (can't see the mods in the pic), drilled all the needed mounting holes and got it painted (still need to poke the holes threw the cross member).
Had some trouble getting the slip yokes but they finally came (they shipped them separate from the tranny's). These things are
MASSIVE, I'm definitely beefing up the rear yoke now haha.
I wanted to add on how happy I am with the quality fit I got with the Quicktime Bell housing, after checking all of the clearances, mounting depths, etc and just the overall quality
"These things are nice" . I'll add the part #s and cost for the latest purchases as soon as I find the receipt as well.
