Paul Boucher
The cloud last night was substantially bigger, but it was a lot colder.Def not from head gasket being blown, you can't mistake that cloud ! Looks like condensation, don't lose any sleep over it ....
I just spoke with my uncle and he said the same. The old oil was not milky, the new oil is not milky, and I don't see a drop in the coolant. If my dad could be here he would probably tell me the same thing, but he can't be, and all I see is the exhaust smoking after my first attempt at an oil change and think to myself, WTF?, did I just jack something up? I will keep an eye on all the levels and consistency for the near future and post updates just to be on the safe side.Humiditiy and condensation will settle in the crankcase and the exhaust system. Soon as the temp rises enough to evaporate, then you will see it as whiteish exhaust untill the water is gone.
Thanks, I will probably try that next time. I was reading that it would help the oil drain better and pick up any debris during the drain. I read to run it for about 5 minutes then let it cool for about 15 (I think) so it wouldn't be scalding hot, but warm enough to flow well. Cold it took about 30-45min to drain.FYI, you should always do your oil changes hot.
here's mine from a couple years ago...it was around 45* outside and it had been a couple of weeks since I started her.
Mar if you parked the car on level ground, instead of pointing up in the air, it might let the condensation out!![]()
I guess you've never seen a car do a cold start up when it's about 0* or colder? It makes a big cloud!The cloud last night was substantially bigger, but it was a lot colder.
Yeah I was reading that it would help the oil drain better and pick up any debris during the drain. I read to run it for about 5 minutes then let it cool for about 15 (I think) so it wouldn't be scalding hot, but warm enough to flow well. Cold it took about 30-45min to drain.
Thanks a lot! It's been tough. He has a rare form of brain cancer, bone cancer, and got MRSA. Been in the hospital since January 11th.My best wishes for your Dad.
Thanks! He's 68.Prayers for you and your family, Paul. how old is your Pops?
