- 12:36 AM
- Jul 31, 2014
- Newcastle AU
Looks like with so few flights these day, all those non-flying 737s are going to need a check up. (This doesn't refer to the grounded 737Max 8). Planes that aren't flown at least once a week need an inspection, and that could mean 2,000 planes.
https://simpleflying.com/faa-emergency-directive-737/?utm_source=pop
That is a very interesting picture with so many different aircraft in a small area.
And why did they need to increase ground clearance? They already cantilevered the engines forward and up and with normal nacelle the engines still picked up stuff from the ground. The 737s legs are too short for the engines. Or vice versa. Changing the nacelle also required reducing the fan size.Not necessarily the shape itself, but the shape is there because certain auxiliary components were tucked up to the side instead of being below, to increase ground clearance.
