SUPERSTOCKRACER
402? wanna trade?
Doug
dont you have 572-13 385cc indy's? thought yours flowed well over 410-415.
402? wanna trade?
Doug
Nope, -1 Hand ported by MCH, Old sheets show 380.
Doug
I got wrong information sorry
how many cubic inches
572,285/292@112, .799", 14.7 Weisco flat tops .043 ring gas port, BME 7.100" rod,2.25" int -1 Indy by MCH, Jessel belt, T&D 1.7 individual shaft, 7/16" trend pushrods, 750 Eddys, Indy C25 intake, GZ vacuum pump. Only ran 10" vacuum and 32 degrees timing for initial tests.
Doug
Misprint on my part , manifold is a 440-25. Track was cold and windy last week,this week it was snowing Saturday. Maybe next week. I made a bar change today. Trans is next.Doug, I thought you had a indy 440-25 intake on your car. I tried 32 degrees yesterday and it didn't like it,went back up to 35 degrees and woke up the car big time. just was testing new motor but the track couldn't hold the power the track was green.Cold,damp and no sun.
that sure is a perty engine there...
Here's what I get out of that reply. Well tube = emulsion tube. Bottom of well tube before discharge nozzle = inside the cluster where the emulsion tube presses in. Drilling this restriction out will pass more emulsified fuel into the air stream.
One thing to note that on all carbs the holes along the emulsion tube can be different sizes, quantities and positions depending on the carb. Changing the size, location and quantity of those holes will affect the mixture at different loads and RPM ranges. For example if you want to richen up the top end you would close off or make smaller the top holes. Weber carbs have a ton of different emulsion tubes that allow a basic carb body and venturi size to run in different applications. I would not mess with emulsion tube holes unless you have a way of seeing the effect. The size of the high speed bleed is a way of adjusting when the main discharge comes in and that probably shouldn't be messed with either.
I'm not familiar with that gas since I don't run it in my street junk, but if the chemistry requires to err on the rich side then as you know more fuel must get into the engine somehow. Opening up the passage in the booster venturi where it makes a right angle turn into the discharge tube is a start and possibly even opening up the discharge itself. There should be a soft plug in the back of the cluster that will gain access to the cross drill for the main discharge. Opening up these passages will pass more of the emulsified fuel mixture into the air stream and that should make the mixture delivered to the engine richer.
Oh, and to keep the same mixture ratio with the larger jets you might have to add a small hole up high in the emulsion tube or increase the high speed bleed diameter to allow more air. Most of the Eddy carbs don't have a lot of emulsion tube holes so I'd tread lightly there. I'm wondering if you just start by opening up the internal passages in the booster cluster and see where that goes. And remember increasing the diameter of a tube follows the inverse square law, where doubling the diameter = a 4 times increase in flow. Sneak up on it. Do you have a mill to do these mods on? And I hope you have an O2 sensor or race pack to check the final mixture result.
thanks for your reply, makes sense.
so what would you do to the carb if i want to run Q16 oxygenated fuel and i'm already at .116-.119 jets.
i'll need to go up 6 jet sizes so an internal mod would be necessary to keep these jets the same and not go lean.
I'm surprised it needs to jet up that far. Secondary jetting starts at 107, 119 is 11.1% larger area. Primary starts with 113 jet and .047 power step on the rod. 119 with a .037 rod is 20.5% larger area.
Doug
