- 10:36 PM
- Aug 29, 2019
- Jarvis, Ontario
I stopped by the machine shop and the heads are back together. Baby steps.
You and me both. It has been dragging on a bit, and I hope it is finished soon.A cool back to basics build
looking forward to see the dyno sheet/runs
Yeah, Dave; I noticed they were getting about 20 lbs. heavier each year, a while back, and started turning people away. Ironically, I am on my third one this spring. The one I am rebuilding now, I got in a parts swap, and is a good one. It is a 1970 from behind a 383 HP, and has a lot of good stuff inside, plus Hi-stall torque converter. I figure this will likely be the last one I do.Nothing new with the engine. I picked up the transmission core today. I unloaded it into the garage, and then sent my buddy a message to see if he would rebuild it for me. He said bring it over tomorrow night or Friday, so back in the car it went. When did they start making them from lead?
Maybe they can start recording at a lower rpm instead of 3400 rpm.I had to go in for a procedure this morning, so I had some downtime. I found the dyno results from the first stock stroke 400 I built. I can't believe it was 2005, almost 19 years ago to the day. We'll see how close this build comes to that one. I have stepped down on the cam from 222/234 to 214/224, but most of the rest of the specs are similar. That one had a nice flat torque curve. That was my buddy Tom at the controls.
