showard
Holy Cow!! That looks beautiful in that spring Arizona sun.
The guy at Electo Tech warned me if I drive the car in mountains where there is a lot of multi path I will quickly learn to hate that analog FM. He agrees the AM is rocking but not the FM.They have not built a radio yet that I couldn't get up to snuff. If caps don't do it I will figure it out!
(Disclaimer: I may need a schematic and blow the dust off ye ol'10MHz scope)
Could you take a good shot of the back of your fuse box when you get there? I need to double check mine has the wires in the correct spot as some of the light wires were free floating when I got it.
Send me a PM with your model number and we can discuss. I'll look to see if I can get a schematic (sometimes antique radio forum guys will scan for free).What would you charge to refresh the stock radio in my 62 Belvedere? It works fine but sometimes fades on its own. And I bet it is coated in dust.
I had a stack of pink wires all connected to each other for the light package that were disconnected because a wire was shorted back to the trunk. My fuse box has 5 slots, one empty. My fsm doesn't make sense how everything is suppose to be connected. I do have a spare 6 slot fuse box I could use if I need an extra slThese is one above. What do you need that is different? What is the fundamental question. It is becoming clear as to the design philosophy of this electrical system.
Did any documentation come with the new harness such as wire color and tracers? I assume the colors were replicated on the new harness?
Crap, found the pics of the back above...perfect. I really need coffee. Thanks.
