JimKueneman
One end routes down the driver kick panel to connect to the harness heading back to the blower motor.
The other connects to the AC fuse clip for power
Whats next for accessory harnesses?
Pink and the orange clip into the fuse box
The flying leads off the bulk head connector harness get the connector shell that was in the Year One harness bag installed and plug into this accessory harness.
Finally the other end just routes down the kick panel area, any guesses? This is the wiring to the neutral safety switch and console lighting!
Now what do we have for an accessory harness? This is the harness that has the timer for the ignition switch light that is tied into the door switches so the ignition light comes on when the door is opened I think. The larger bulb socket with the dual wire yellow connector and round 90 degree brown connector go to the under dash map light and its switch.
Few simple harnesses, the pink runs from the fuse box to the glove box light and the orange are the ashtray light and clock light.
