moparnation74
Is that the original tank? If the sending unit is original and has the 3/8 fuel and 1/4 vent. I would be interested in that. Shoot me a PM if you want to sell that...Pulled the fuel tank and lines:
Removed the brake master cylinder, brake pedal assembly and brake lines.
When I pulled the front right wheel I found the car came with the optional disc brakes.
Removed the caliper and rotor:
Removed the upper control arm and found the bumper disintegrated:
Pulled the torsion bar back to remove the strut and lower control arm:
Lower control arm bushing was completely worn through on one side:
Next I will remove the splash shield and then on to the other side. The goal is to get it completely disassembled and then media blast the shell so I can better assess the condition of the floor pans.
Justin
