Well,I sorted out the spagetti mess of wiring for the underhood area.
Mating a 1973 Satellite engine/ignition harness with the original Charger harness,the seat belt interlock is gone!
Only the headlight and tail light harness left are original to the car.
I tested everything with a multi meter for contact and made sure there were no open curcuits.
Upon closer inspection,the Charger suffered a catasrophic nuclear meltdown sometime in its life prior to James buying it.
Plopping in a motor/trans and hoping it fire up in "as found" condition would never be possible.
The ECU was melted so bad exposing the guts,the horn wire was melted to bare copper for a good 28 inches.VR and field wires at the alternator was MIA.Some of the interlock wires were cut and twisted together.
Funny that the fusible link was not fried.
What was not melted after the car was left for dead,critters snacked on the insulation on the wires to bare copper.
So,I had no choice but open up everything,inspect,and repair as needed from the bulkhead to the headlamps.
I re-wrapped the harness with brand new correct wrapping tape,so it looks good and compliment the freshly painted motor and engine bay.
Look good,yes..but will it work??
Tomorrow,I am bringing my 73 Shop manual :book1: and a fire extinguiser,LOL!!
I will install the harness and double check connections before putting juice to it .
Once it is all OK,James can fire up the mighty 360.
A pinnacle moment when the car comes alive!!
