Ron 73
Deceased, But not forgotton
It sounds like its all good, The rest should be easier on the thought process!
So you're saying the front offset hangers wouldn't clear the frame because the 4 studs wouldn't line up with their holes, or was it the big nut (inbrd) that holds the bolt thru the spring in the hanger interfering? My studs didn't match up with the stock holes in the frame, so I opened them up a little. I posted a few pics and went into detail about the problems I had with the hangers and how I fixed them. If you haven't read thru that part of my thread you may see something that would help. I'm happy with mine, now! But it is stupid of them for not making them to fit.Working on getting my offset hangers installed right now, for the cal tracks too. Man I wish they would have used the right bolt pattern. I had to move the holes outboard about a 1/4 also to get them to clear the frame rail.
Here are a couple of parts out of the molasses after 18 days. I water rinsed them and blew dry with shop air. There is a little flacky paint left and some minor black pitting that may have gone away with a few more days in the vat. I will now hit them a little with the sand blaster. I will have to say this is working great for me, so far. My small sand blaster is slow and not an easy set-up to use. Using the molasses will cut out probably 80% of the blasting, I would guess. I would highly recommend the molasses to anyone, unless you have a really good working sand-blast cabinet or can get a good deal from someone else to blast stuff for you.
Got the skid plate installed. Thnx Hunt!
