roadrunnerman
I like the way the floor "flows" back. I can already see once you get it welded, sealed and primered how smooth it will look.
The last few days working on the Fury have been pretty amazing; after many years I am finally in a position to begin fitting pieces back to the car as opposed to nothing but repairing. What a feeling! OK, the repair on the corner of the setback/firewall is being a pain in the *** but otherwise...
The first thing I wanted to test fit is the dash since the steering column and pedals mount directly to it and the driver seat aligns with it. Surprising to nobody, least of all me, it was instantly obvious the stock pedal assembly will never work and the steering column is going to need "some" work.
This first picture shows the dash in place, alleviating any fears of whether the height of the engine setback would interfere with the underside of the dash or defroster tubes.
This picture, from a bit of a different angle, shows how the steering column centerline will go through the setback. If you squint really hard you can see a light vertical line on the backside of the setback. That line represents the outside edge of the engine, including headers and valve cover, meaning I may have up to 4" or so of room to slip the steering column past the engine.
My initial reaction to the situation is to use a VERY short steering column with one universal under the dash, an extension passing through the firewall, another universal in the engine compartment, and another extension leading to the rack. This will necessitate using a rigidly mounted heim as a bearing (passing the rack extension through it) but I have TONS of space to mount one.
Before spending any money on a tilt column I'll modify the existing column, cutting it way down in length and develop the rest of the steering from there.
I agree with your approach with just modifying you steering column, there's a few things in this hobby that I'll never understand and one is buying an expensive column "it's a tube with bearings that turns the wheels, not a go fast part for crying out loud". Nice work
carnalsupply
have posted a few new pics today if you would like to check it out
Hemijoe
believe it or not they are nova rails 67 to 72 pat number 3035 from Comp Eng
carnalsupply
cant wait to see how you are going to put peddles on this car that's really got curious
She's looking great Bob! Coming together quite nicely.
That really cool ! !! Now you've got a "nice" place to sit and make engine sounds while working on your car ! ! ! Thanks for the update ! !
( I still have to sit on a bucket . . . ) ( smile )
Very nice, I like the seats. Don't understand why more people do this because it sure beats sitting in the old seats. Curious what your going to do to seal the floors up where the hooks come threw (box them in)?
nice work, newer car seats in the older cars is a good way to make driving them long distances more comfortable.
