71airgrabberRR
Hey I've been following your post, great work. I have done several restorations, but never a mopar. I have a 69 roadrunner, the previous owner did some poor floor patches, so I am putting in a one piece amd, I am also putting the body on a rotisserie. Would you recommend to replace the floor pan before it goes on the rotisserie and then finish it underneath on the rotisserie. Or would it be ok to replace on the rotisserie, either way should I use supports in the door opening? As well I want a really nice clean finished job, I have a set of sub frame connectors, would you recommend to use them? Are they really needed? My goal it to have a similar finished product as your duster, it looks awesome.
Thank you for the compliments.
On my Duster I installed the sub frame connectors first. Then I mounted the body shell to the rotisserie and removed the entire front floor section. Then I installed an AMD one piece floor while it was on the rotisserie by spot welding and MIG in a few spots.
The sub frame connectors really stiffen the body up. On my Duster you could open and close the doors easily with one side lifted on a floor jack.
But honestly if you don't have a stout big block with a 4 speed or if your car hooks up really good and your NOT going to race the car, they are not really needed.
I have a Dick Landy built 440 going in my Lime Green 70 Challenger. The car will have a 4 speed. I will probably install connectors AND box in the spring hangers on this car.
I hope this helps.
Hey, you have the same stain on your left side rear floor pan as I do .
Are you talking about the grease stains on the bottom side????
Lol.....
As promised today I experimented a little with the different nozzles etc.
This is what I found out:
With the wide fan nozzle I was able to remove all of the undercoating on the front side of the cowling (where the emergency brake bolts against the firewall) in 10 minutes. The wide fan leaves a very clean undercoating free surface.
Then I went to the smallest nozzle. I was able to remove undercoating in an area of about 1 square foot in about 3 minutes. However the finished surface was not as smooth as it was with the wide fan. The pin point nozzle left behind a little residue of undercoating behind. 95% of the undercoating was gone.
This is how the underside looks now...... There was hardly any undercoating here. It was mainly road dirt and dried clay.
I cleaned a little over half of the driver side.
This is the inside area of the driver side rear quarter panel wheel well. This was a test to see how quick the pinpoint nozzle was. I was able to do this in a little over one minute. It still needs to be fine tuned. You can see the leftover undercoating residue on the metal if you look close. The areas that had undercoating are blue. The areas that did not have a surface rust brownish look.
I just realized that I did not answer all of your questions. Sorry about that I was using my phone to post so I could add the photos I took today.....
As far as the frame connectors go: I'm not 100% sure if I would have attempted removing and installing the whole floor section while on the rotisserie if the car didn't have them installed, but it is a whole lot easier to get to everything that way. I have been debating that with the RR too since it will not have connectors........... If the rest of your body is good, I would say probably OK to do it. Sorry to sound like a politician here..........
I did not install door supports when I replaced the floor pan. I think they become more of an issue when you are changing out a cowling and / or quarter panels at the same time.
By using my buddies spot welder, I was able to duplicate the factory look. But it really didn't matter, because most of the spot welds were covered by seam sealer, and the rest were covered by carpet.
