71airgrabberRR
Cave Man Style !!!!!!
No, the only tools I used were 3 different sized hammers (a large and a small Ball Peen), a vise, a set of electricians lineman's pliers (klines), a "Uni" bit, and a short piece of a 2 X 4 .
No. I simply secured the patch to the wooden blank that had a groove cut into it. That way it wouldn't move as I was trying to hammer in the channels.
I used a sandpaper roll from a cylinder head porting kit to grind out the recess in the wood.
The top photo was a test run on a scrap piece of metal to see how it would turn out.
No I just used the wooden blank and the round end of a ball peen hammer.
I placed the round end of the ball peen over the groove, then hit it with a plastic coated dead blow hammer so it wouldn't move. I'd be weary about striking one hammer with another metal one. I had a piece of shrapnel from one get lodged in my hand years ago by doing that. Every since then, I haven't done it again. Now I even make sure the end of my punches all stay ground down too. It only takes once...........
I always wear glasses too................
Once I had the rough shape of the channel formed, I removed the patch from the wooden form. Then I laid the metal patch on the flat surface of my vice and straightened it out using the vise as a back stop instead of the wood. It made the grooves nice and flat. It takes some time, but it can be done. Just take your time and be patient with the metal.
71AG, you have surpassed any level of amazement I had when you first started this thread. Did you use a flange tool after you cut out the holes.
Holy crap Louis!! That patch looks great. Did you just use a hammer to make those recessed areas or did you hammer in a round bar or something?
