Also, anybody have a recommendation for wiper motor refurbishment? One of the guys that is commonly recommended here is local to me, but I haven't heard back from him so I'm open to other options.
Contact @Topher
Which position is your shifter in? It's a bit hard to tell from your pictures. Also, did you get the offset shifter to put it in the factory location? I'm going with a 2015+ Challenger console, so mine will be in the middle.Thats about where mine landed.
View attachment 1502435View attachment 1502436View attachment 1502437
Not exactly sure what you mean by position, but it is where the 71 B or any of the E bodies are just in front of the T bar cross member. I have not gotten an offset shifter however I might, I want the shifter to be forward a little like the 71 B with bench/buddy seat would be because I am going to be using a mid length PG.Which position is your shifter in? It's a bit hard to tell from your pictures. Also, did you get the offset shifter to put it in the factory location? I'm going with a 2015+ Challenger console, so mine will be in the middle.
The TKX has two shifter locations. The stock position is in the picture above. By removing the 6 bolts in the picture below you can rotate that plate 180deg and move the shifter forward ~3". Mine will clear the cross member only in the forward position.Not exactly sure what you mean by position, but it is where the 71 B or any of the E bodies are just in front of the T bar cross member. I have not gotten an offset shifter however I might, I want the shifter to be forward a little like the 71 B with bench/buddy seat would be because I am going to be using a mid length PG.
Gotcha, I was severely mistaken, my shifter comes up behind the cross member. I don't know what I was thinking there.The TKX has two shifter locations. The stock position is in the picture above. By removing the 6 bolts in the picture below you can rotate that plate 180deg and move the shifter forward ~3". Mine will clear the cross member only in the forward position.
That's a pretty cool idea. I'm going to be using the classic dash bezel so I'll be losing the radio position to additional gauges. I like the idea of using the speedometer cable hole for the harness. The problem is my computer is going to be mounted in the glove box (I think). So there's no way the harness will reach that far from the driver's side. The plan for now is to run it up underneath the heater box and go through near the center hump on the passenger side down low. My concern is that it'll be too close to the headers. As soon as I can mock up the motor, I'm going to see how close it is. If it's far enough away or I think I can make a heat shield I'll do that. Otherwise I might have to go through the cowl or some other less ideal solution.You ever settle on a wiring harness pass through location for the terminator?
I’ve found that the terminator fits perfectly inside the old AM radio. I’m thinking about mounting it inside the old radio shell and depinning the harness to go through the old speedometer cable hole. I’m moving the battery to the trunk, so the larger gauge power and fuel pump relay wires won’t need to run through the firewall.
