Pretty sure I'd have parts. Is the output shaft itself OK? I fixed the same failure for a customer this summer,
Output shaft appears to be OK except for a few bruises, will post some pics!Pretty sure I'd have parts. Is the output shaft itself OK? I fixed the same failure for a customer this summer,
It’s an emergency brake and WHAT does it have to do with being in park?Yes...
Cracked rear pump housing, broken park gear, vaporized governor mechanism. A&A(Rick) hooked me up with everything! Put in spacer to eliminate gov. made plate to replace park mechanism cover. Removed all the mech. Back together - working fine sitting on jack stands, waiting for snow to go and dry roads for test!What did you end up finding?
I have extra park mechanisms and cables. I will be 78 in March, maybe the next guy will park it? LOL!Weremived the governer and thinned the park gear down to 1/4" wide. Also trimmed off part of the snap ring boss in my racecar. Then cut a new groove in the output shaft, so no need for the spacer. If you ever decide you need park. I have a good source of parts.
Gary
Thanks for the compliment - yours looks pretty as well!Man that turned out to not be too bad at all... i stress about that tailshaft and am keeping a eye out for a spare just in case something happens. And man that car is pretty.. wish mine were a post car![]()
Fortunately for me, I know some history on your son's car! It's out of my league - perhaps a race with index - eh! My "Sinister Savoy" runs low to mid 10's - 1.40's @ 60 ft!
Lookin good! Still a full sec quicker!!! Lost a couple hundred lbs with the Savoy between myself/ previous owner and Lingenfelter light weight brackets and light weight glass bumpers (Sled City). Running the aluminum wheels (in storage, similar to Torq thrust D's) would be a few more lbs! The Crager's look nice but heavy....Ah but it's been toned down. Now that it's a dedicated racecar it's not as fast. No more turbo small block. It's lighter and slower. Though it's losing another 100lbs this Winter. Current best is 9.68 vs 9.55. Yours sure is prettier.
