All I know is that if I had a 3-1/2" exhaust pipe, my farts wouldn't be half as entertaining.
I was thinking the same, just couldn't think of a nice way to express it!I’m also in the collector extension camp.
But there is likely a loss of TQ in the launch rpm/shift recovery region that may just be gone with the bigger tubes on that combo.
Don’t take this the wrong way, but that engine combo isn’t “hot” enough to make proper use of 2 x 3.5 headers.
But some extensions should perk it up.
LOL!All I know is that if I had a 3-1/2" exhaust pipe, my farts wouldn't be half as entertaining.![]()
I appreciate it, but I don’t care about nice.I was thinking the same, just couldn't think of a nice way to express it!
I checked the weather for Quaker yesterday vs 6-15. Yesterday was actually slighty better. Are these the 2 days you are comparing. Also looks like a big tail wind yesterday. Biiger header equals less velocity through the port. Less velocity has less pull on the carb. I'd try jetting it up 2-4 jet sizes. My bet is your car would like a Performer RPM intake. The 2" aren't ideal but they're not that far off. Looking at plugs after driving the car in the pits is useless. Push in the clutch, shut the engine off and coast to the end of the track. Bring a couple of spare plugs. Swap them then look at the plugs you pull back in the pits.The weather was a little worse (DA) but honestly the weather doesn’t seem to affect it a lot.
Depends on who you are trying to entertain!All I know is that if I had a 3-1/2" exhaust pipe, my farts wouldn't be half as entertaining.![]()
Doug
Is it necessary to use brand new plugs?I checked the weather for Quaker yesterday vs 6-15. Yesterday was actually slighty better. Are these the 2 days you are comparing. Also looks like a big tail wind yesterday. Biiger header equals less velocity through the port. Less velocity has less pull on the carb. I'd try jetting it up 2-4 jet sizes. My bet is your car would like a Performer RPM intake. The 2" aren't ideal but they're not that far off. Looking at plugs after driving the car in the pits is useless. Push in the clutch, shut the engine off and coast to the end of the track. Bring a couple of spare plugs. Swap them then look at the plugs you pull back in the pits.
Doug
IF the combination is working well, I have no problems using 'used' plugs but if I'm trying to find out what the problem is, I will use new ones. Some say no way but after awhile, you find out what works and what doesn't......Is it necessary to use brand new plugs?
YesIs it necessary to use brand new plugs?
I appreciate the advise, but I’m not changing headers again!MANY years ago, Jere Stahl (Stahl headers) told me, 'in order to use a 2" primary, the engine needs to make a minimum of 550hp'...I find that to be very accurate! 1-7/8" will be your best bet, depending on how much HP your engine makes.
That’s another way to go, build it for 550 hp.MANY years ago, Jere Stahl (Stahl headers) told me, 'in order to use a 2" primary, the engine needs to make a minimum of 550hp'...I find that to be very accurate! 1-7/8" will be your best bet, depending on how much HP your engine makes.
I haven't had the opportunity to do a header comparison like you have done, but I have 2"headers on three cars, one small block (yep, custom built to fit the oddball chassis), and two big blocksThat’s another way to go, build it for 550 hp.
