Sweet5ltr
After nearly a year you have finally taken my advice, now get those gaskets on and ENJOY THE CAR! :hello2:
I really hope to get something done soon. The daily commute beats me up and leaves me worn down to a nub. I feel great at quitting time but after 2 1/2 hours of driving home, I am burned out!
I appreciate the sentiments. I work construction and the commute distances are always changing. In Sept 2012 through March this year I was working 20 miles from home. I have 6 years to reach my 30 year pension. After that if I work anywhere, it will be a short drive!
Regarding cam timing: I have a Lunati 316/326 Solid in there now, degreed in at the recommended 106 centerline. Retarding a cam is supposed to have the negative effect of reducing power at low rpms.
I thought about trying the thinner gaskets to gain quench. The problem is, I am already at an average of 190 psi of cranking compression with the .039 gasket. A thinner one would only raise those numbers. I can't help but think that even with quench, there is a point where the cranking compression is just too much for the fuel we have here.
What carb do you have? Single plane intake or dual plane? Agreed the idle is way lean in gear and fixing that may be beyond mixture screws. You may need to try a different carb or metering block with larger idle fuel restrictions. Accel pump shot is not the answer here. WOT under load and max RPM should be about 12.5:1 A/F. I don't like the cruise ratio either and that may be a sign you need a different metering block. The emulsion tubes can play a big roll here. The number, size and position of holes will allow the mixture to be fine tuned within different RPM ranges and load characteristics. It's not just about jet sizes and PV's. But before you mess with the emulsion tubes, a smaller carb might help just because you will have a stronger vacuum signal. If you currently have a race Holley that may be at least part of the issue. Carbs like the DP series are really made to perform best under WOT. Not to go around in circles too much, but you also have a big lumpy cam, so you may be stuck with a certain amount of inefficiency. At that point tune for WOT so you don't burn the pistons down, get the idle as best you can and don't let it load up. High overlap has a way of messing up street driving characteristics. Or install a 114 LSA cam and have the tunability you are looking for.
