OK, how's this for a data point? This was found on the archives of Moparts, data from a real person. I like to build on the knowledge of people that came before, just like you always do with science. There's been so many of these stock stroke and stroker 440s built. Why reinvent the wheel?
"as a 440 with open chamber iron heads and pistons .100 in the hole, it was an 8:1 (if that) pig that detonated on premium. after the rebuild, it's zero deck, .039 quench, 10.33:1 496 that never detonates."
Not sure if this is a good data point. It seems that too many thing were changed at one time and the big thing was the condition of the engine. Was the engine CC'd and found to be 10.33:1? I CC'd my 440 and came up with 10.1:1. I am running 915's with a flat top piston -.015" in the hole and a steel shim gasket. It pings like crazy on pump 91 with the iron 4 BBL and 750 AFB. Add a splash of 110 and the 4000 lb car runs high 12's. But now I have a 6 BBL and my pinging is gone - and the 6 BBL is lean!! No other changes were made. My explanation is fuel distribution has improved or perhaps I had one very lean cylinder with the 4 BBL and that is now cured with the different intake and a pile of carbs.
If Gregory C was willing to try a pair of cheap steel shim .020" head gaskets as an experiment, he would find out soon enough. With his pistons .017" down and the .020" compressed gaskets, he'd be at .037" quench. The labor, time and cost would be nothing compared to what he's been going through and if he did this along with correctly curving his distributor for the combo he might have an engine that is realizing the full potential of all the high-dollar parts he has in it (aluminum close-chambered heads, 1.6 rockers, stroker crank, etc...) and probably really scream if he ever took it down a track in a properly set up car.
I don't agree that correctly tuning a distributor is a band-aid, I feel that putting a thick head gasket on a motor with close-chambered heads is a band aid and makes no sense to me. What was the point of ordering the 84cc close-chambered heads if he was not going run an engine with good quench numbers? May as well have ordered the 88cc open-chambered heads and used thick head gaskets to lower the compression and not have all these problems.
I never said correctly tuning a distributor is a band aid. I said altering the timing (i.e. limiting or retarding) to make a high compression engine live on insufficient octane was a band aid. Adjusting the compression ratio for the available fuel is not a band aid. This is the proper solution to the problem.
He went through all the trouble to change rockers and cam to have enough lift to realize the potential of his good breathing heads, now why not go all the way towards straightening this thing out?
I agree with what you saying about it's a streetcar so build a streetcar but he's already gone down the road of overkill for a streetcar so he may as well go all the way. Let's face it most people, especially those that are never going take their car to the track would have more fun and more money in their pocket if they just put together something like what IQ52 put together for his dyno day. But people get caught up in having the latest stuff...
