mr. b
that is looking great almost there let us know how it runs
So do you guys change the breakin oil right after a cam breakin or wait 500 miles?
Cam breakin is done! Followed lunati's intructions to the letter. No leaks, no overheating yay!
Man that engune throws a lot of heat though. Cooked my hands pretty good adjusting the throttle stop.
Now I can schedule the exhaust and alignment!!!!
Are you going to get that thing on the road before the north freezes over again? ;)
I'm going by my own experience, and what most of the guys reminded me of, that the BB Mopars respond best at 36* to 38* all in advanced timing. Example...my distributor has 24* advance set in...24* from 36*=12*. That's where my initial timing is set.I still don't quite get how to set the timing to the way guys are doing it today with initial and at a certain rpm, etc.
Only gauge on mine that didn't work, was my fuel gauge...nothing. Knew the gauge itself was good, since I tested it. Checked using a test light, to see if I was getting power to the sending unit, off the wire. Yeah, it's reduced, on, off, then will blink.
Checked ground, first at the sending unit, to fuel line...big resistance. Wound up the re-pop ground strap over the rubber hose connection. Dang cheap thing wouldn't make good contact on the steel fuel lines. Wrapped a piece of 12 gauge wire around both lines, for a test...gauge works perfect. Just have to find a good strap, now.
Maybe one more hint. If you look at the steel fuel line, from the tank connection, it goes straight up to the body, and makes a bend to the passenger side. At that bend, above the tank connection, should be a screw hole. On mine, there's a steel clamp, around the fuel line, that fastens at that screw hole. That's the 'positive' ground connection, for the gauge.
I'm using a Mallory dual point, mechanical advance. The 24* advance that's 'set in', simply means it's that number of degrees, that the adjustable stops are set at. The amount of advance degrees, can be adjusted, by those stops. The rate, or how slow/quick can be adjusted, by the advance springs. If you have your distributor in place, in the engine, pull the cap. Then, by hand, twist (in rotation) the rotor...the amount, or degrees, the rotor rotates, is the amount of 'set' advance degrees, in your distributor. If in a fix, you can use a draftman's degree wheel, starting at 0*, to get an idea how much advance you have, even if it's a little crude.What do you mean your distributor has 24* advance set in?
Yep, your correct. The sender scale is wrong...though should be adjustable, via tab stops. Have to pull sender to get to them.The sender though has 87ohms with about 5-6 gallons of fuel in the tank. This seems off the scale as I thought the range is about 10 ohms (full) to 73 ohms (empty).
Glen,
Nicely documented. I've got a 63 polara with a Poly. I'm going to swap out that engine for a 413 as well. Sounds like my C body oil might might fit afterall. Not sure of the number on the pan... What about the torsion bars? Did you reuse the 318 ones? I was thinking I'd need to upgrade to BB bars.
So I guess it's not so much a rusty can of worms anymore? Great work! I really like the way the headlights are set up with the grille on those cars.
I tossed 10 gallons in my tank, to see if it read about 1/2. After some running I've done, and got the gauge to work, reads just under 1/2, now.
The worms are alive...Congrats!
