Time out. Hold the phone....
Here's the clutch/fan with a bolt run up snug on it:
Folks, that's just too tight for comfort for me. About an inch up top, less than that below accounting for the tilt of the engine.
Not only that, those mounting bolts on the clutch to pump are a NIGHTMARE.
Ok, one more pic for tonight. Here's the shroud placed on the studs:
Maybe about a quarter of the fan blades are actually within the shroud lip.
That's not desirable either, obviously.
It's quite apparent that the shroud is designed to work in conjunction with the stock thickness clutch - and both are designed to work with a radiator that is much thinner, too - not anything like this Griffin, which is ALL the thick.
Final nail in the coffin is my being picky - the radiator needs to move towards the drivers' side another half inch or so to be truly centered on the pump/fan.
That will also expose more of the core to the air as well (refer to the first pic in post #108 and you'll see the shift).
This initial attack was not successful. Time to back off and regroup...
P.S.: Something else I found interesting in this mock-up tonight - the radiator support has those raised ridges the radiator fits up flush against, holding it a little less than a half inch off the actual face of the support.
They wanted a gap in there for whatever reason - a gap that helped make things too tight on the fan/radiator clearance issue.
Not only that, the shroud is also designed to mount off the face of the radiator by a pretty good amount (looks to be about 3/8") as well.
Look at the shroud pic above closely and you can actually see the gap and the little pads molded into it that make it do that.
Now, given both those obviously intentional gaps by Ma herself, is it actually wise to seal up those gaps like so many folks do?
Things that make you go hmmmm.....
