Dragon Slayer
So here is the difference between a Prestolite and Chrysler distributor that shows you how the clips are different position when VC points in same direction. Also notice how the Chry cam stop notch is 90deg different. That is because the rotor notch is 90 different between Chr and Pre rotors(constant). Though you can't see it I had the tip oriented the same.
The picture from the chiltons is accurate based on the Chrysler and that is also why it makes sense about shifting wire one hole for prestolite. The generic diagrams that have you straddle clip clearly would not be correct unless the rotor point one over too.
If you google hemi engine and view images you can see a lot close ups of various car with Prestolite distributor, with enough resolution to follow #1 wire to the distributor. I just found it interest how they were located in so many different spot it prompted my original question based on the variations I have found it Prestolite distributor parts.
Which does not even get to the question of what are the correct prestolite part numbers in a OEM Hemi distributor. 50 years of rebuilt an refurbished can change the characteristic of parts in my opinion.
