1 Wild R/T
My shop is full of steel shards... But only one set of steel feeler gauges tucked away in my tool box...The shard of steel on the magnetic pickup.
You must get all steel fragments away otherwise you can get false timing and erratic readings.Your eyes are better than mine. I had to get the reading glasses to see that.
It is probably a strand from the rivet I filed down. Maybe I'll give this a quickie blast of compressed air before using it.
Thank you.
The six reluctor has just one grove in it for a roll pin and obv. six points. Yes the pickups are defiantly phased. One of the reasons for the "phasing" reluctors being made really. Have a 6 PU in a 8 la it is off, in a RB it is off, etct. If it is properly matched, you will never have any phasing issues. Just one of those things people came up with. Thats why the roll pin holes are set. If actual phasing was off it would be a random amount between parts.Never did use a 6 pickup but never thought it would be different.....just thought the reluctor would be the determining factor.
The stuff that sits outside of the car is usually underneath it at least and most of the time being used. I've worked on enough rear ends to know what they look like inside if they've been out of the car and sitting on the ground. Stuff around here will sweat inside if left out in the elements when the weather is cool and dry and then a warm front comes in from the south with high humidity.I do my best to keep my stuff tucked away. I keep the weather sensitive stuff indoors but other stuff sits outside. Body panels, axles, springs and wheels are outside of the car so they sit outside. Engine parts, interior, electronics and gaskets have to be protected.
File cabinets are excellent for storing small parts rather than stuffing them in boxes and stacking them.
My girlfriend now is like that. My X used to bitch about the work clothes I wore (mostly around the house though) and well, she was also always 'needy'....I'm fortunate to have a wife that is so easygoing about my interests, it would piss off the other wives.
She never hassles me about the money I spend, the shows I attend or the way I sometimes look. I try to balance out my hobbies with giving her full attention when she needs it. I am blessed.
I got mine when I bought a 72 340 Challenger in early 74.I bought these brass ones in 2001 when I got the MP ignition kit.
A major variance in the reluctor feeler gauge measurements might suggest a worn bearing on the shaft.I was curious so I checked the gaps on the old original one I just got.
Yep, the gaps are very constant and only one feeler gauge blade did fit (in this case 010).
A big difference from my newly made dist.
Old stuff wins again.
I missed it when I had the reluctor wheel off. With it in place, I really can’t see it.The notch is there in post number7, third picture from the bottom.
True. But in this case it was a brand new Dist that varied, while the old used one was spot on.A major variance in the reluctor feeler gauge measurements might suggest a worn bearing on the shaft.
Only way that can happen is the upper dist shaft is bent. One reason to check the gap on all the points. Been doing these for a long time seen alot.True. But in this case it was a brand new Dist that varied, while the old used one was spot on.
I agree with his ideas on vacuum advance, vacuum advance in its current form came about to enhance fuel economy and ring wash. It is not supposed to be part of the mechanical advance mechanism of a distributor. It’s like the overdrive gear in our modern automatic transmissions. It naturally find its way into that gear but the minute you nail down the throttle it disappears like was never there.The 8 LA distributors I showed were all OEM as far as I knew. I pulled them from wrecking yards and parts cars I bought. They all seemed to have only one roll pin in them.
The two RE distributors I posted have two roll pins each, filling both grooves. The reluctor does slip up and down slightly on the one I had apart today.
I respect Ehrenberg and enjoyed reading his tech but I've also seen him stubbornly stick to some things that have been disproven. One of his claims was that one shouldn't use the later FMJR disc brake knuckle/spindle for fear of it over angling the upper ball joints leaking to failures. These have been used for years with zero reported failures yet he stands by his warning.
He is a strong proponent of using vacuum advance for street cars. He dislikes the coil over front suspensions for street cars. I don't know enough about ignition systems to dispute anything he says. I've seen the stock points and electronic systems run a long time in my cars and others so I'd need to see some accounts of problems others have had to get me to consider other systems.
For now, I'm going to try the FBO advance limiter plates like these:
I agree with his assessment on vac advance. Vacuum advance, in its current form, was designed to increase fuel economy and reduce ring wash. It is not supposed to be part of the distributors, mechanical advanced curve. Think of an overdrive gear in our modern automatic transmissions. In normal driving it finds its way into that gear. But when you mash down the throttle, overdrive disappears like it was never there.The 8 LA distributors I showed were all OEM as far as I knew. I pulled them from wrecking yards and parts cars I bought. They all seemed to have only one roll pin in them.
