FINALLY!
Work has been nuts. Add to that a pretty intense medical testing round of pokin' and probin' the last
couple weeks PLUS a nice healthy suspension from fbbo and here we are.
Today, I decided mid-afternoon to just say "fluck it" and head to the garage; enough is enough.
One good thing about Fred sitting there on jack stands in the back, wheels and drums off, was that
if there had been any leaks from anything back there, they would have manifested themselves by now.
Thankfully - there were none.
Ok, let's hose everything down with Brakleen and see if I can remember how to do this....
Reminder - this car had only the star wheel adjusters on it, which were supposedly held in place by
the cross-spring directly above them - a system that proved so unreliable that Mopar went to the fancier
self-adjusters next time in the cycle ('69 for some sizes, '70 in the case of 11" drums like on Fred).
Not only was I going to be replacing linings and hardware and such, I would be converting it to the
more modern self-adjusters - and hoping the combination of Wagner, Mopar, Eis and Porterfield branded
stuff would work together in doing so.
As it turned out today - yep, it all worked, quite well, with only minor tweaks needed here and there.
Here's what I started with (passenger side shown) - typical ratty old brakes, relined and with the metal actually
heavily pitted and painted over with some manner of glossy black whatever to try and hide it.
They were so out of round that parts of them weren't even making contact with the drum:
Just cheap, crappy shoes - but at least they had plenty of meat left, so they didn't score the drums.
The hardware actually looked original!
Well, off came all that crap, followed by a good scrubbing of the backing plate, etc.
Note: Of both the new hardware kits and the self-adjuster kits I bought, neither contained a new parking brake
cross bar or the diamond-shaped heavy washer that goes over the top post and up against the shoes.
Fortunately, both are quite heavy and were cleaned up to be re-used.
Tools at the ready and parts at hand, I went at it with new stuff - and short of the shoe retainers (dumbass me
lost my specialty tool for these, which WILL get replaced before I tackle the fronts!) things went quite well
considering the aforementioned mixing of brands as well as the upgrading of the hardware:
(Picture is slightly bleached out; camera flash was a little strong in this shot)
Everything went together just like it should (and is shown in the manual)...and as I went, the memories of
brake jobs long ago started coming back to me as well.
The newer design self-adjusters went together great and it was cool to see them functioning before my eyes.
I ran the adjuster up just so the drum went on without a lot of slop, then buttoned it all back up.
CAVEAT: It took a LOT of adjusting to get to that point, indicating the old drums are pretty darn thin.
I'm certainly going to be on the lookout for a deal on some 11x2.5 drums as a result.
The drivers' side went similarly and a bit quicker, now that I remembered how to do things...
Of course, an obligatory quick shot of black on the drum faces was applied as well - hey, Saturday morning brake job by a redneck, remember:
Once Fred was all back together and on the ground, I cautiously got in and worked the brake pedal a little
bit - SLOWLY - to see what was what (rear brakes determine pedal, I'm told) and after a couple pumps, I
started hearing the adjusters working!
I hadn't expected that, figuring the car would have to be reversing in order for that to happen - but sure
enough, as quiet as it was in the garage, I could distinctly hear the adjusters clicking away with each pump
of the pedal and the pedal became higher and firmer!
Last thing I checked was the parking brake - no drama there, either.
Sore and nasty from sitting on concrete too long, I called it an evening right there, satisfied.
I reckon the fronts are next!
(Pics will enlarge if you click on them)
