Factory correct looking under carraige (primer with overspray), what process and materials are you using?
Coincidentally, I just received a large order of SPI epoxy and white SS paint. I’m going to try it out and see how it compares to PPG DP.
This is my '71 Duster, done in the spring of 2022. I used 3 coats of PPG DP50. The over spray is single-stage (EV2). I used a bit of thinner in the primer. It has a satin finish with a very slight texture. It dried to a more bluish-gray. I have a $100 Astro gun, don't remember what the tip was. Also can't remember if I scuffed between coats. Since it's under the car it won't be subject to UV rays so it should last forever.
That said, if I ever do a correct-type restoration I'd use the Resto Rick paint for sure. A friend of mine used it on the spectacular restoration of his '68 Coronet. Looks really good.
The bottom of the Duster here was clean clean clean. Took off the factory undercoating with a torch and scraper, was a lot of effort. Some areas where there was surface rust and/or hard to reach were blasted with a cheap HF blaster using black beauty media. Once the undercoating was gone the factory 'gray dip' primer was evident underneath and I left it where possible. I used cheapo truck bed liner in the wheel wells. Not 100% correct but close enough for horseshoes and hand grenades.
As I said mine is going to be a nice driver so I don`t need it 100% correct but I do want the correct look and not a fully body color painted underside like most do. I am worried about how the epoxy will hold up both chalking and chipping so I`ll at least spray a matte clear over everything or maybe a gray single stage and just clear the overspray. My car only has undercoat in the wheel wells and I will reproduce that, the Resto Rick stuff is about the same price as Raptor liner so t`s kind of a toss up there.
Now that you mention it, I actually used Raptor Liner in my wheel wells! Sorry, I totally forgot. I did thin it out though. I also used a primer gun instead of the schutz gun that the kit comes with. I used the cheap bed liner paint on my rear axle though. It came out OK but the R.L. is a better product for sure. Anything you mix together and use with a gun is going to be more robust than something from a $13 spray can.
If you are concerned about durability, Raptor Liner is actually a good option for the underside especially since you can get it tinted to match whatever color you want. Thinning it out also makes it smoother if that's what you're after. Kind of the best of both worlds.
I built my GTX long before I knew what was correct, so I painted the entire undercarriage and engine compartment with single stage Deltron. That said, it’s held up really well considering it was applied in the late 90’s. I drive the GTXeverywhere, and it’s seen more rain than I care to recall. Last year when I put in the TTI exhaust I spent a day or two on cleaning the undercarriage while it was easily accessible…
I found a couple examples of the "army green/grey" on the car I was cutting on yesterday........... you can clearly see the dip line
