You’re off quite a bit, about 7-8 degrees if I’m doing the math correctly…
So measured right?You’re off quite a bit, about 7-8 degrees if I’m doing the math correctly…
The points where that angle finder are attached are not representative of the true angle. Housings are not square and level to the centerlines of the rotating parts inside. The transmission case has no plumb or level parts to attach to except the bellhousing flange and the tail shaft seal flange. The axle housing is just as bad. You have to attach to the yoke itself, not the housing.@HawkRod @Black_Sheep , and anyone else that knows better
Ok, my cheap amazon angle finder came in, probably not the best one to use but here’s the numbers. If I’m not mistaken engine is is down 1.45, and my rear is up 6.4 degrees. I also found at one point I put shims under the rear, and doing research they’re 2 degrees, I must have misread something 7 years ago and thought it needed to go up,
Idk
Pictures 2+4 are the useful ones, and #4 I would put the finder on the flats where the u joint strap bolts to.The points where that angle finder are attached are not representative of the true angle. Housings are not square and level to the centerlines of the rotating parts inside. The transmission case has no plumb or level parts to attach to except the bellhousing flange and the tail shaft seal flange. The axle housing is just as bad. You have to attach to the yoke itself, not the housing.
Did I see that right?
i put the angle finder on the yokes and on the housing because I didn’t know the best place and just went everywhere hoping one would be correctThe points where that angle finder are attached are not representative of the true angle. Housings are not square and level to the centerlines of the rotating parts inside. The transmission case has no plumb or level parts to attach to except the bellhousing flange and the tail shaft seal flange. The axle housing is just as bad. You have to attach to the yoke itself, not the housing.
You're on level ground on all 4 tires I assumeNot for a direct an and b test, but I guess my previous numbers doesn’t matter. I’ll remeasure tomorrow
yesYou're on level ground on all 4 tires I assume
sorry late to the thread 1st I saw of itWell, I built my car before I became a member of this great forum, so I’ll give you guys a rebuild thread. So the backstory on the car. I had a 68 satellite 4 door, and a couple dodge trucks, but I really wanted a 1966-7 or a 1970 super bee, but truthfully they’re all beautiful so my search was for a 2 door, 4 speed. In 2017 this 1968 GTX came up, it was a roller with no title, but it was too good to pass up. Being a fan of the 70s street freaks and street machines, I set out to build a tribute to that golden era. I repainted the engine bay, after 4 years of rebuilding, repainting, and rewiring it was finally a driver! After 2 years of driving, some of my budget fixes started to show. Every gasket on the 440 is leaking. And I built a Frankenstein 833 iron case with 833od guts a week before a road trip, didn’t have time for new gaskets, so reused the old ones with a lot of silicone and prayers, yeah as expected that didn’t work. After going through the home buying process, and slowly gathering gaskets and seals….oh yeah and a camshaft, because it’s a non hp 440, and if I’m pulling it out, might as well!
For some reason, I thought about you today on my way to a car show. Lol.View attachment 1450523
Can you put it on hereView attachment 1634000
Idk
I agree. you need to use good attachment points that are representative of the true angles. None of the housings are good to use.The points where that angle finder are attached are not representative of the true angle. Housings are not square and level to the centerlines of the rotating parts inside. The transmission case has no plumb or level parts to attach to except the bellhousing flange and the tail shaft seal flange. The axle housing is just as bad. You have to attach to the yoke itself, not the housing.
Good idea! I used the point referenced by Kern Dog below for the pinion and a straight edge across the balancer pulley, but I like the socket idea.Find a deep socket that fits the diff yoke in place of the u joint, it will give a good surface for the angle finder. Same for the trans tail shaft, hold a socket on the end of the tail shaft to space it out past the seal.
That still isn't a square and plumb/level mounting spot.
What you need is a straight edge here:
It has to sit flat across the mounting face, something like a paint stirring stick from the hardware store.
