I get it, and by no means intend any disrespect. Quite the contrary, it seems like you have a good handle on clutch operation, finding the sweet spot for clutch and throttle, as well as tire selection.
I am such a big proponent for a ClutchTamer or HitMaster launch control system because I don't get to go to the track as often as I want to, or need to, because I have so many "systems" of my car that are out of whack.
My leaf springs for instance....What makes me think that my 50 year old, factory high performance leaf springs are worn out is that the top pick (of 2) pinion snubbers from Mancini bent badly on the very first run I made, and then so bad on the 2nd run I had to abort the run and remove the pinion snubber so I could drive. They must be wrapping into an S like crazy. I tried to get a friend to video my launch, but a wild monkey would have been a better candidate.
My T.O. bearing is making noise, and I wanted a hydraulic one anyway, so as part of a TKO600 purchase for the GTO I got a hundred off the Hydramax from American Powertrain. So the HitMaster is my choice now, where I was going to get a ClutchTamer. I could go on, front suspension, brakes, all of those parts are in now, so that is next to be installed.
