1 Wild R/T
Solid Plan... Dwanye is a good source of info and parts...
I am going to call Duane tommorow just to touch base after the labor day holiday . Like you said, I need to set up a plan . If I could get to the 600hp range using my block crank and rods for $8000 I would be extremely happy . I guess I am wondering if that price sounds reasonable for my expectations. I don't want to sound like a total fool. At least anymore then I do now.lol
600 hp is easy with 500 inches and Trick Flow 240 heads. You don't want the 270 heads since they are Max Wedge size and would be too big for what you are trying to do. The cam you have might be okay for 600 hp but it is a little on the small side. The 496 in my Coronet made 610 hp with a 239/245 hyd roller so your cam is close. I have no idea what your compression will be with the TF heads and it doesn't sound like anyone else does either. You most likely will need to pull the heads off and measure to find out. Odds are that you'll be fine. You don't need a lot of compression to make 600 hp with the TF240 heads. If I was designing a street motor from scratch I'd shoot for 9.8 compression with a zero deck and a dish and then use a 0.035 or 0.040 MLS gasket. That combo will make power and live on the street. Good luck, sounds like you just need a good local shop to work with.
What type of rpm range is your power at . I mean what is your redline do you have ? every book I read and website I read tells different information I've always heard a 500 or similar size motor would choke out with 240tfs at high-end? What cfm carb and type is on your Coronet? Compression ? I'm impressed!how does she move in the quarter mile ?600 hp is easy with 500 inches and Trick Flow 240 heads. You don't want the 270 heads since they are Max Wedge size and would be too big for what you are trying to do. The cam you have might be okay for 600 hp but it is a little on the small side. The 496 in my Coronet made 610 hp with a 239/245 hyd roller so your cam is close. I have no idea what your compression will be with the TF heads and it doesn't sound like anyone else does either. You most likely will need to pull the heads off and measure to find out. Odds are that you'll be fine. You don't need a lot of compression to make 600 hp with the TF240 heads. If I was designing a street motor from scratch I'd shoot for 9.8 compression with a zero deck and a dish and then use a 0.035 or 0.040 MLS gasket. That combo will make power and live on the street. Good luck, sounds like you just need a good local shop to work with.
Are you joking me I was just reading chapter 18 this morning !!!! That's like a Bible of knowledgeIn case you aren't aware of it AndyF wrote the book on big block Mopar Strokers... listen to him...View attachment 828026
