rumblefish360
See ya around the neighborhood !
Come west young man,,,,,,,come west!.......to Bellmore.See ya around the neighborhood !
I've ran a few different cams in my 440/493. All have been flat tappet style, two were hydraulic while the other 2 have been solid. I don't race the car on the dragstrip but I do enjoy some spirited street driving.
I'm at 10.0 to 1 compression with ported Edelbrock heads, 2 inch headers, the Performer RPM intake and a Demon 850 vacuum secondary carburetor. I have the Mopar Performance 528 solid cam and am using 1.6 roller tipped rocker arms.
I've been slow to finish but am trying to add A/C back to this car. It is an original A/C car but I I went with a Classic Auto Air setup to save weight and to have an all electric system. The kit comes with the small Sanden compressor.
I keep hearing about how roller camshafts can give a nice increase in torque without losing street driveability. I want to drive the car more...I love the car but keep finding excuses to drive something else. I am not disappointed in the performance of the car as it is now, I just wondered what I might gain. I am fine with adjusting valve lash so a solid roller cam is fine. I suspect the lifters for a solid roller setup are probably cheaper than hydraulics. I thought I remember hearing of troubles with hydraulic roller cams that idle a lot...I don't recall the specifics.
I have 3.55 gears and a 28" tire. Soon I plan to swap from my 727 to a 5 speed kit from Silver Sport Overdrives. Currently I have an 11" converter that performs great with this cam.
What is your combo? Do you have any suggestions?
Well, THIS got really complicated....
I am not looking to pull the engine apart to bush the lifter bores. I just thought that even though these roller setups cost more, maybe I could squeeze out a little more power with no drawbacks.
I have raced the car before but I mostly use the car for cruising, distance driving, car shows and hopefully someday, road course fun.
I read a few articles over the years about how a roller cam can make a nice jump in power without a loss in idle quality. I did have a more rowdy Lunati solid flat tappet cam and liked it, I even saved the lifters in the proper order. I've twice used the EDM lifters from Johnson and have had no trouble with them. Maybe I'll just stick with what I have.
Thanks to all for the suggestions.
I've always thought the greatest drawback to the .528 cam was the silly .028"-.032" lash settings.
my opinion is to maintain .010" between the tappet and base circle on the cam. multiply that by the true rocker ratio and use that number as valve lash minimum. the fly in the ointment here is tight lash flat tappet cams; which I don't understand a need for.Makes me wonder how tight you can go.
A tighter lash cam is as far as I know only for quieter running cams.my opinion is to maintain .010" between the tappet and base circle on the cam. multiply that by the true rocker ratio and use that number as valve lash minimum. the fly in the ointment here is tight lash flat tappet cams; which I don't understand a need for.
Good point, Fish. That is why I asked the man at Lunati Cams about valve lash. He said that the lobes are designed with ramps of various rates. If the lash is tighter than ideal, the edges of the lifters want to dig into the lobes!
WHAT ???
Since I know a little but not a LOT, I took him at his word and stayed with the spec that was called for on the cam card.
True on the money thing. The recent rise in prices a few items sucks and intakes were a bit of a surprise. I’m not exactly ready to pay nearly $400 for a new intake. It’s even worse with the MoPar Magnum stuff. DANG!I'm not disappointed in the performance as it is now. I did lose some punch when I went from the 3.91 gear to the 3.55 but I expected that. I made that gear swap because when I had the 3.91, I also had a Gear Vendors unit in the car. When I sold the Gear Vendors, I switched to the 3.55 just to make freeway driving tolerable.
I will be switching to some shorter tires that will have the effect of a deeper axle gear. The 5 speed will stir things up as well, since it has a 2.87 1st gear ratio compared to the TF 727 2.45.
Finally, I did not expect to see the lifters cost so much! In 2013 when I was considering the same thing, I thought I saw Hughes or Comp lifters for under $500. I figured I could do this for under $1200 total. Not that money is everything but jeez...
Roller cams in BB mopars ,as you all know there is no plate to retain the cam in the correct place like the 318 family of engines.
with Hyd/solid cams the lobe is slightly tapered high in front side of lobe. with the lifters having a slight convex bottom surface this keeps the cam from moving fore and aft in the block. when you switch to a roller the lobes are flat and there is nothing to keep the cam from walking forward- and it will. there goes your timing if lucky- if unlucky the lifters can fall down behind the lobes .
to run a roller cam you must have a front cover that will provide access to making a button retainer to hold the cam in place. I have done this by welding a stronger plate in the backside of the cover and a button the correct length to retain the cam. this works if you have the 3 bolt cam, single bolt cam,must find another way.
this would be the only determining factor for running a roller on the street. they are actually very nice cams.
