What can you do when it is raining . . . but spend time in the shop ! !
Got out to the shop this morning due to it raining here ( probably all day ) and got the last of the spot welds ground off and the last of the metal removed from the rear of the car and then thought . . . how is this going to look ? ! ? ! ?
So I was off to grab the donor panel and see what it was going to look like . . . I think I'm glad I went this route now ! ! !
The rear of the car will be welded on the normal weld areas . . .
The trunk area of the car will also be able to to be welded in the normal weld areas . . .
However, the difference in the top portions of the quarter will require some additional thought . . . but I think I have a plan . . .
Cut it down the top of the panel on the side to keep my original top section in place . . .
And an angled cut across the back to replace the damaged top area and lean the original top section in place . . .
And the end result is that I will have minimal bondo in the car and a much truer, cleaner looking quarter panel as a result ! ! !
Got a lot of work ahead of me this weekend ( no tree work to get in my way ! ) . . .
After I get everything fitted and lined up, I'm going to weld up all the holes, grind them flush, and get all of this in epoxy primer before it gets put back on the car.
