Outsider
Ok with the piton ID now we know something about the compression potential. So what is the cranking compression?
Though you won't be able to double the HP with bolt-ons, you may be able to get maybe 30% more power with a better suited cam selection if the existing is not ideal for the intended use, then carb tuning and perhaps a new intake and a set of aftermarket heads and adjustable rocker arms. Another 100 hp would be significant.
