I pm,d you but your inbox is full?Hi James is there somewhere we can buy the grease from to use in a grease gun for maintenance.?
James From
PST
Inbox Should be okayI pm,d you but your inbox is full?
James From
PST
I have been trying to contact PST and can't get through. Put on hold....I pm,d you but your inbox is full?
James From
PST
Will the shackle bushings fit an original shackle bracket? What kit do you sell that fits a 1970 charger? Are the shackle bushings installed with lubricant?Here is a link to how the FBBO discount works.
B Bodies Only Member Discount
If you are wanting to us Paypal you would will need to place your order through our website as we do not take paypal on phone orders.
James From
PST
So the old rubber outer sleeve remains in the leaf spring? Burned out and then the new poly and inner sleeve is placed inside the outer sleeve?If you want to use your original shackles here is link to the kit you will want. But you will need to measure your main eyes. They could be either 1.5" or 2" For the main eyes you will need to remove your old rubber and inner sleeves prior to installation
Polygraphite Rear Leaf Spring Bushing Set
NoHave you ever had a problem with the poly bushings backing out of the LCA?
Did you install them inside a rubber shell? Burn out the rubber? Use sleeve over the bolt?
I will measure. I think I’m gonna take the plunge and hope it goes well with the PST kit.I'd buy that kit to replace the polyurethane in the Hotchkis shackle. The Hotchkis bushings have an inner diameter of 7/16" and an outer diameter of 15/16"-1". Are your shackle bushings compatible?
I did call twice and will call again. I was put on hold for over a half hour and just so you know coming from a buyer you can’t tell when a caller is placed on hold. No voice that comes up. “We appreciate your patience. A representative will be with you shortly “. Nothing but silence. The last time I called I “placed on hold” and after waiting a half hour the phone disconnected. The first time I called I have to say the representative wasn’t very patient with my questions.What has been your issue with calling (800-247-2288) us ? We have 4 salesman on staff from 8:30am to 6 pm Monday through Friday? I am a bit confused, your thread is about leaf spring shackle bushings but you are now referring to LCA (lower control arm bushings) bushings. So what is it that you are looking for? Our shackle bushings install just time oem rubber the steps are the same. The only thing different is the you will need to apply a liberal amount of the grease supplied when installing the bushing to initially seat the bushings. Do you need LCA bushings as well ?
James From
PST
I will call. I am east coast and have to wait. I was referring to a different thread. Thank you for responding. I want your product. I just want to have it straight in my mind because I live in a rural area and I know the shop hasn’t installed them before and will need to explain the installation. Will the front end kit and leafspring bushings come with installation instructions? LolI am sorry if you were on hold as that seem unusual as well as what you described. But I am still confuse, are you looking at shackle bushings or LCA bushings? LCA are lower control arms bushings and are found in the front of the vehicle. So I do not know if terminology is being confused. Are you trying to refer the the main eye bushing on the leaf springs these are the large front bushings on the leaf springs? I have not seen any negative comments in this thread in respect to our product so I am confused by your statement. I have responded to all your installation questions so I do not understand the issue.
When you do call I would ask that you call and use the extension 326. This is a direct line to our one salesman John W. He is one of our seasoned employees and can aid you in putting any apprehension to rest.
James From
PST
The LCA I was told needs to have the rubber bushing burned out and the new polygraphite bushing pressed in place. Does the bushing get lubricated on the outside where it goes back inside the outer shell of the lower control arm bushing? Is the installation of the front Eye of the leaf spring going to have the same installation procedure as a lower control arm? Do you burn out the rubber and install the Polygraphite Bushings for the leaf spring in its place? Do you use an inner sleeve? If so from the original or does an inner sleeve come with the kit? If I don’t get all the answers from this post I will be talking with your representative later on today thank you.
I’m trying to understand if people had issues with the lower control arm bushing walking out the front what could’ve caused that because I don’t want to duplicate the same improper installation.
Did you ever find out whether the bushing shell in the front of the leaf spring gets left in or not? I'm ready to do this job and I don't know whether I should burn out the bushing and leave the shell, or try to push the whole thing out.
