Tony Tee
I work at a company that make urethane foam parts and use molds made of urethane and fiberglass. I like urethane but only in certain applications like bump stops. Or springs. I don't like urethane that is used in a twisting or bearing application. Or near heat. The melting point of urethane is about 100°c or 212°f google it, if you don't believe me. And there are a lot of areas under the hood that get pretty hot. Sway bar end links strut bar bushings are OK. My car has home made poly-lock type engine mounts that I don't know if they will hold up. And sway bar end links are urethane. Everything else is rubber. So choose wisely...Just my 2cents!
