76mopar
1979 Chrysler - blown 408. 10.50 @ 128 mphView attachment 332860
Details on the setup. Would love mine to run that good.
yes nothing except park. Starting to pull today.Are you saying your transmission DOES NOT WORK NOW ? wow...
Let us know.
my best was 10.706 The suspension is set right and the tires bite like a mad dog. ThanksThat's one sweet RR. Wish mine had the balls to lift the front end off the ground. Looks like a great pass.
well I never got to it today. Bottle Rock Napa this weekend. Priorities and I bought the tickets some time back. Looks like tuesdayYou run a trans brake correct? My bet is you stripped the front planet on the output shaft. The other possibility is that the belleville spring broke in the rear clutch causing it to jam and burn up. Either way easy fix. On my sons trans we replaced the planet with a steel part from A&A. On mine I just consider them maintenance and replace the stock part when they start to bind when sliding them on the output shaft during assembly. He runs high 9's with a trans brake at 3775lbs, mine 9.0-9.1 footbrake at 3350lbs.
Doug
I bet you meant 10.706 not 10.076.....lol...your pal, Mikemy best was 10.076. The suspension is set right and the tires bite like a mad dog. Thanks
correct my badI bet you meant 10.706 not 10.076.....lol...your pal, Mike
146 is a great 60 foot. Nutting wrong at all with your 10.88 for a 7000 pound car.
