Thanks for the input. I have the .110 Needle & Seats. I will try lowering the pressure and see. Its a 472 cu. Did you ever have the surging?
When does it surge Ernesto?Thanks for the input. I have the .110 Needle & Seats. I will try lowering the pressure and see. Its a 472 cu. Did you ever have the surging?
I'm about to leave for work, but have you tried around 18-20 degrees of advance at idle with a way to limit total timing? My FBO ignition and more advance at idle really helped my 440 6bbl.At idle to about 1600 rpm. It idles around 950. If I let out the clutch too quickly it creates a bucking sensation. If you've ever heard a roots blower surge, its like that except milder. No vacuum leaks. I've tried higher idle speed but this screws up the AFR's.
Would tapping the carb spacers for vacuum help for the signalI'm at 18 degrees initial and 34 total with MP distributor and a chrome box. I have also tried with and without vacuum advance. I have always leaned toward the cross ram and the lack of a vacuum signal but others running this manifold seem to find the sweet spot. I will continue testing. Thanks
I appreciate being invited to join in on your quest and the suggestions by our fellow forum members.I appreciate the help everyone is offering.
I agree and will celebrate with you!My surging is virtually gone and she returns to idle properly. In addition my vacuum gauge isn't swinging from 5 to 13" hg. She is at a steady 9" hg. I pulled 2 degrees of initial timing out as she was idiling at 1300 rpm. This dropped her to 1000 rpm. I am calling this a success as I have been trying to cure this issue for a while now.
Would you mind going into detail about those 2 items? I have a McLeod RXT dual disc clutch and pressure plate setup that is broken in, but unfortunately STILL haven't had time for a trip to the track, and only a couple of limited flogging events on the rarely trafficked street that runs through the 2 wildlife reserves. I expect GREAT performance from the McLeod.Had to eliminate a pesky rear main seal leak, replace the clutch (went dual disk), and install a PCV system.
