- 1:29 PM
- Jan 16, 2011
- NorCal Sierras
When using anti-seize,
the "wet torque" value is like (?) 20% lower,
than usual "dry torque" values std.s,
less torque is needed, wet
instead of 14#s more like 10#-11#s (don't over tighten them)
regardless of style of plugs,
gasket style (old MoPars, shitload of foreign/Japanese stuff)
or tapper seated (GM/Ford etc.)
(Certain Ford engines have real issues with plugs sticking/breaking off in the head)
I've use it on every style of engine since (probably way earlier) 1974,
I remember stepdad Bob, telling me "make sure to use anti-seize"
using it, at about 10-ish on my Tecumseh engine in my
Taco 44 mini-bike sparkplug (7hp Motor out of a rototiller)
especially on 2 stroke or 4 stroke engines
"especially if you are taking the plugs in & out a lot",
(Like 2 stroke engines or racecars, especially heads up/pro classes)
Used it in/on a Mastodon Hemi, BBC SBC BBM SBM BBF SBF MG/BL
& almost any car, truck, O/B, M/C, Kawi, Yamaha, Honda, Husky, CZ.
Merc/Evinrude, my mini-bikes, my quads, chainsaws, lawn mowers,
rototillers, snow blowers, cast iron or alum, etc. etc. etc.
I've 'never ever' had any plug seize/stick because of Anti-seize...
I have used Nickle stuff, I like to use on cast iron,
it's pricey **** 4 times the price
Copper (Loctite stick/tube I have must be 40 years old now) is OK
if I don't have Nickle stuff handy for cast iron or alum
or dissimilar metals
& ol' trusty aluminum/Anti-seize in 8oz brush on bottle,
'that **** that gets everywhere'
most old true/real mechanics even some newer guys,
that have run into stuck or hard to remove dry installed plugs
will say/tell you the same thing
**'use it sparingly', it works
IMO it's a mandatory on alum heads
or stainless bolts/any threads going into aluminum, visa versa, titanium etc. especially
or any type of dissimilar materials
Almost all/every spark plug mfgr say *'not recommended',
Most newer mfgr'd spark plugs 'have a coating baked in/on the threads' already
(Quality Control sucks *** today, it doesn't work as well as it should)
'that's supposedly' to help stop them NOT sticking in the threads
(As some will verify here, it doesn't always work as advertised)
No matter if compression thread/tapper seat or gasketed before the threads
*More/mainly for legal reasons, than 'truth of function',
to cover their own *** mode
(** mostly for reasons below)
*Mostly because people gob it on thinking a lil' is good a ton is great
**you never want to get 'anti-seize' near the electrodes/near the 1st few starting threads
use it mostly in the middle of the threads
**need to keep the anti-seize away from the 1st couple threads
& especially away from the electrode, always
Use it lightly/sparingly too, 'a lil' dab will do ya'
(Remember, like Vitalis for the old greaser dudes)
(On brakes/sliders pins etc., you need to use extreme heat for brakes stuff,
I suppose you could use the same stuff on spark plugs too)
Any Anti-seize (Nickle, copper or alum.) is a form of lubricant as to torque values
many people/even skilled mechanics, when using it 'over torque' the stuff,
they use it on
dry torque & wet torque are different
sorry if;
I went a lil' overly **** retentive on the ****...
Good luck Steve/Biomedcruzdude
they use it on
sorry if;
