- 6:01 AM
- Jul 1, 2015
I'd suggest the 3310 Holley. NOTE: for the N96 setup, you'll need a stock intake manifold & the Holley won't fully sit down on the intake. You can clearance the intake & bottom of the carb very easily. Great carburetor on a 440
I concur.....I had a '71 Dodge Charger 500, WP23U1A******, fairly stock 440, 727B TF, 8-3/4" rear, PS/PDB, all the other features of an R/T with out the badges and stripes, with poverty hub caps and 60 series rubber on all corners, with black steel wheels. I retro fitted an Edelbrock (aka "Eddy") Torker II, open plenum X configuration manifold with a Holley Model 4150, R-3310-1 780 CFM, with down leg secondary booster venturi and a cable operated manual choke. EXCELLENT combination, sharp throttle response, great top end, reasonable fuel milage, vacuum secondaries for smooth, no bog transition. But....I still like the Carter AVS for originality. Just my opinion of course.
BOB RENTON
