- 10:34 AM
- Oct 25, 2010
- Monroe, New York
Yes. It's an 80s issue friction promo.Is that a Jo-Han?
Great job!
Was red with red interior.
I used to have the real car..
it was black with red interior. White top. Factory 440 tnt. Console auto. 3.23 sure grip.
Factory air and cruise control.
Unfortunately....lost it in a fire .
It was a project..but rust free and 100% complete.
I kept the fender tag and sadly sent the burnt hulk to the crusher.
It's near the top of the list of cars i wish i could have back
Have always hated doing plumbing work!!!Finished the wet side of a washer dryer closet I'm adding to my rental apartment. I expanded a hall closet to make room for a stacker, added hot and cold feeds, and both a washer drain and a floor drain in case of leaks. I teed the drains together to a single outlet, ran it to an exterior wall, and down into the basement to tie into the main drain along with the drain for the first floor apartment washer drain. Tested, and no leaks.
I also stubbed the dryer vent up into the attic. Then my DeWalt died - smelled like a fried motorcycle stator so I called it for the day, came home, disassembled and cleaned the motor in the DeWalt. We'll see if it fixed anything or if I'm buying a new drill. I still need to run the rest of the vent thru the attic and outside once I hole saw a 4" hole for the vent...but that will be a morning job. That attic is HOT.
I'm tired of doing plumbing.
My X wanted 'all' the window curtains opened no matter what the temp was outside. It's nice until the 5 ton AC unit runs constantly for a house that's a bit less than 2000 sq ft when the outside temp is 100!! That's when I make sure ALL the curtains and blinds are closed lolWhen we built our house we wanted a lot of windows, big ones, some about floor to ceiling in the great and dinette rooms. 34 windows, majority are casements. I was remiss more than I thought, with the necessary upkeep to make them last. Over the past two-years about ten have been replaced, two more on deck. So far around $40-grand. Most of the remaining windows are ok, but in need of preservation.
We haven’t used many of them much over the years and they get loaded with debris, grass, webs, add the condensation at the bottom of the sashes over the winter where the lower casement linkage is, taking out the varnish and stain. Upkeep should have included washing the frames more, adding treatment such as Armor-All on the seals…just like I do with our rides in spring & fall.
My oversight. Last couple days has been doing this drill, plus sanding down the sashes, re-staining, and varnishing. Two-coats of the varnish. Did re-caulking last year. Lord, recalling what it cost to put in all those windows when we built, that $40k alone for 10 windows, is double what ALL of them initially cost.
My In-laws waited years before having central AC installed, they might have been in their 60’s by then. MIL was a master with opening and closing shades/windows depending on the sunlight direction and kept the house pretty nice most of the time. We had central AC put in when we built, but in our 1st house it was couple of window AC’s and my dad and I put in an all-house fan in the attic. That house fan really helped sucking the hot air out of the attic cooling the house down.My X wanted 'all' the window curtains opened no matter what the temp was outside. It's nice until the 5 ton AC unit runs constantly for a house that's a bit less than 2000 sq ft when the outside temp is 100!! That's when I make sure ALL the curtains and blinds are closed lol
Oh wow!! Don't know what I can say about that! But....I do remember sleeping with my head at the foot of the bed because it was next to the 'window' of the attic fan pulling in the air! Did that lots of times in the late early 60's. Problem was the attic fan was on a 1 hour timer and remember waking up to reset that dang thing lolMy In-laws waited years before having central AC installed, they might have been in their 60’s by then. MIL was a master with opening and closing shades/windows depending on the sunlight direction and kept the house pretty nice most of the time. We had central AC put in when we built, but in our 1st house it was couple of window AC’s and my dad and I put in an all-house fan in the attic. That house fan really helped sucking the hot air out of the attic cooling the house down.
Lol, I’ll skip the time I was helping my dad put in a bedroom AC unit, high window from the ground, at their place when all of a sudden the damn thing came falling out the window on top of me. I tried to hold it knowing it would be trashed letting it drop; but when I felt the sensation of the fins slicing up my fingers that was that, let it crash. Five stitches…
Guess I didn’t skip that story, lol.
Armor All uses a water based silicone emulsion. Despite what some Corvette forums claim, it has no petroleum distillates or alcohol in it. Anyone can look up the MSDS for it. It does contain 1,2-Benzisothiazolin-3-one, which is actually used as a preservative for natural rubber latex.Don't ever use armor all on rubber seals. Go to an RV store, there's a product specifically for rubber seals. RVs use it on the slideout seals. Forget the name at the moment, but armor all will eat at the rubber. It's petroleum-based.
My mistake.Armor All uses a water based silicone emulsion. Despite what some Corvette forums claim, it has no petroleum distillates or alcohol in it. Anyone can look up the MSDS for it. It does contain 1,2-Benzisothiazolin-3-one, which is actually used as a preservative for natural rubber latex.
I'm the opposite. Feed lines are pressurized - more mess when they fail (I'm gradually learning to trust SharkBite fittings...). Drains are gravity...less desirable mess, but less likely to fail in the first place.I don't mind "incoming" plumbing so much.
It's the "outgoing" plumbing I don't really have much desire to work on.
