I like & I prefer the Flowmasters
on both my 99 Dakota SLT 4x4 5.2ltr with a bunch of bolt-ons & tuner
300+hp-ish w/3" cat-back 'single' Series 50 Delta flow
& on my 68 RR American Muscle car system Delta 50s Series
mandrel 3" exhaust system all the way out the back
tailpipes out the rear, yes it's a tad bit louder than some,
IMO They are heavy (
they are steel & IIRC are like 5"+ x 20"s+) is the only real downfall...
but;
I like the performance & tone it's not wimpy, or tinny
IMHFO it's suppose to be a bit obnoxious... it's a 68 RR
I prefer the tone of the Delta 50 Flowmasters,
I'm not a huge fan of the 40's, it's too loud, & too tinny, for cruising)
over the mild straight through sounding Dyno-Maxs, guys I know that have them
or from some that seem to love it/them...
I just didn't like the tone, especially at idle
I get
no "alleged" noticeable 'dreaded drone' some claim either
Mine the difference between uncapped 'tuned'
& with full exhaust 'tuned' was like 12 hp
(most of that ET difference is probably weight)
I can live with that...
Bare with me a long backstory...
I had a good friend Mark Lowe
(professional head porter, one of the best at the time, may he RIP)
he help me do some finish porting work, on my RRs combo
back in early 2000s
I was curious, I ask if we could do it, so we set it up
we did a flow test with 1 header installed, at 0.600" gross valve lift
(for what would be 'the then' 1.5:1 rockers)
with 1/2 the 3" Muscle Car pipe/system H-pipe blocked/tapped off
& out thru the full muffler/system 1 side, all the way thru/out the tailpipe,
what a PITA that was, had to move & stack **** to hold it all up...
this was Back when I ran N2O on the street, did a lot of cruising
& occasional street racing still, out Scott rd. or El Camino in Sacramento Area
it's lil' 383/479cid 4.15" stroke & 4.290" bore, 700hp+ before N2O
that car went best of 9.77 @ 135 with
no N2O, full exhaust
3,520#s, worn out M/T Drag Radials
org. with a 6bbl, flowed 940 'real cfm', not the 350cfm center & 2x500 cfm ea. outers/1350cfm it's rated at)
& best run/pass on N2O 8.58 @ 156 thru mufflers/tailpipes,
with a single 1050 Holley Dominator/actually flowed like 1200+cfm,
w/a 350hp (more like 300hp) Top Gun plate kit, big Powerdine Solenoids,
10# bottle w/1,900#s bottle pressure, 5 psi on the fuel side, 'flowing'...
Anyway I wanted to see if the exhaust system was really killing it,
like so many 'wives-tales' & usually all "
total conjecture" I had heard over the years,
so many people that don't know what they are actually talking about,
&/or those that repeat it all on the internet now
unfortunately on the flow bench we actually couldn't replicate the N2O added effect or not
But;
it actually had a slight scavenging effect with the full exhaust on,
less than a 10 or 12cfm on total flow/cfm #s out the end,
very lil' noticeable backpressure, less than a 1 PSI difference out the tail pipes
& after 36" or so of a pipe 'of straight tail pipe', after the H-pipe 20-ish inches back ,
it didn't make any differences, it was the same, as if we had a full exhaust
heads made the most flow/cfm like 335cfm 'intake flowing' for power at 0.600" GVL
(Cam was a 0.660/0.690"-ish with 1.6:1 rockers GVL, I actually ran later)
for the test w/a makeshift tube at the intake port
to replicate an intake manifold
with 18" collector extensions, open headers
headers were a cobbled up set Hedman's, I made work in the car
1-7/8" to 2" stepped at like 12-14"s in a 32" long tubes,
into the (heavy) Flowmasters 4-2-1 scavenger header collectors,
& the 3" Delta Flow 50 Series 'Muscle Car' system mufflers full kit
I was pleasantly shocked, I was actually completely surprised
I don't even think, the Dyno-Max straight thru mufflers weren't out yet then too
I don't believe all the BS hype & total conjecture or "alleged" #'s on manufacturers spiel
about all mufflers, they all are trying to sell you their mufflers...
IMO (my experiences) their major advantage of the Dyno Max vs Delta 50 Flowmasters
is less weight & being IIRC 18ga. stainless steel...
I suggest people check out the
MotorTrend's Engine Masters episodes on it
they did the test on a IIRC (Freiberger's)
800+hp NA 1 4bbl Brodix headed 477cid BBC 4.5" big bore x 3.75" stroke
It confirmed what we figured out many, many years ago...
The old org. type 'Hemi Turbo Muffler' sold by all the big chains
killed the most power, like 50-60hp (or more ?), they're quiet,
but they robbed power
IIRC the Flowmasters Delta flow, don't remember the series #s used,
were like 12-15hp killed, on their makeshift full cobbled up 3" exhaust
on an 800+hp combo...
