Ranger16
OK, gotcha, but assuming that black thing is a pointer, I don't see a leak point unless the intake gasket as Shorthorse said.
5 pages of this thread. The original poster reved the motor to the moon. We've had discussion about spark, carbs, fuel, oil and yet a few bolts haven't been removed to look at the valve train, really????OK, gotcha, but assuming that black thing is a pointer, I don't see a leak point unless the intake gasket as Shorthorse said.
6,000 on a 340 is not to the moon.5 pages of this thread. The original poster reved the motor to the moon. We've had discussion about spark, carbs, fuel, oil and yet a few bolts haven't been removed to look at the valve train, really????
Doug
I'm getting there. Takes time, which is in short quantity these days.5 pages of this thread. The original poster reved the motor to the moon. We've had discussion about spark, carbs, fuel, oil and yet a few bolts haven't been removed to look at the valve train, really????
Doug
Also, it briefly hit 6,000. I didn't hold it there for 10 seconds.6,000 on a 340 is not to the moon.
I did find a vac leak by an intake bolt. Might have to replace the gasket. Not sure yet.Most likely, it was someting carb related and has cleared itself. Something mechanical usually doesn't just go away. Drive and monitor...no need to tear into it if she's running fine.
Why is this?if its sucking oil it very well could be.
youll see the bad spots/pattern on the old gaskets when you pull them off.
and hey drain your radiator first okay.
make sure you drain the lower hose going to the radiator as well.
