Post a picture of what you have going on..
Trunk lid to high & raising the latch seems like the wrong adjustment to me..
USArepoWhose (brand) gasket did you use ?
yes
Thanks but they are not the same.This guy has 2 for sale individually, but not sure if they would work for the X.
FOR SALE - Prices start at $10......Back of the truck sale! - 66 - 70 B- Body Small parts...switches, brackets, emblems, etc, etc, etc...
Back of the truck sale!... Prices start at $10. - Small parts...switches, brackets, emblems, etc, etc, etc... Some parts are 66 67 B-body & some fit 66 - 70 B-body. Ask if your not sure. ...shipping extra... If possible, I will try to combine shipping to save you $$$. (The 2 switches have the...www.forbbodiesonly.com
Trying to clear some space in my garage so I cleaned up the wiper linkage and painted the motor and then installed it.
Pulled the dash frame out to follow the suggestion of assembling on the bench before installing.
Noticed that the chrome rocker switch button on my headlight switch is in pretty bad shape. Started looking for some place to buy just the one I need but having no luck.
Anyone have a source for these? I don't want to have to buy a set when I only need one.
FYI, the radio piece for '68 does not have any lettering.Waiting for some under dash insulation to arrive.
Decided to start assembling the dash as suggested by someone on here.
Took a look at my woodgrain trim and this is what I found:
Decided to see what I could do with it. First I took some different colored objects and put them behind the faded area to see if it would make a difference.
A piece of treated wood seemed to match quite well and I happened to have some wood stain the same color.
I held the part up in front of a light so I could see my progress:
I kept on with it trying to cover any areas where the light was shining through. I even found a red that matched the GTX letters but it was difficult to get good coverage. The chrome paint areas are extremely thin so not much I could do there but I did try.
Plan to shoot clear coat over it hoping to get a bit more depth to the color.
I still need to find a radio surround piece since I do not have one.
Seriously?FYI, the radio piece for '68 does not have any lettering.
Wow, you are correct from what pictures of original cars I see.FYI, the radio piece for '68 does not have any lettering.
There was a member here remaking them. His name eludes me at the moment.Wow, you are correct from what pictures of original cars I see.
That means it will be near impossible for me to get a correct one.
