- 9:21 AM
- Jul 1, 2015
As far as the operation of the valve train, the easyist to operate the engine with the valve cover removed....it sounds as if an exhaust valve is not opening fully, due to a worn lobe or a bad rocker arm....they have been known to fail where the push rod socket pushes thru the rocker arm. If a valve seat or valve is damaged, a compression test will disclose the problem.Thank you Bob - good stuff. How can you tell it is an Eddy or you just know? My mechanic thought it was a Carter probably because he thought it was original.
I was able to contact the second owner of the car and he said that in all the back in the late 80s, he had the original 318 engine 2 bbl swapped with a "1973 440 donor engine" and also they put on a new carburator on it at that time. So don't have any original carbs. The second owner also told me that he later had it converted to electronic ignition. The choke is electric too.
As far as the potential valve issue, the mechanic told me twice he removed the valve cover and didn't notice anything unusual. My brother told me though the only way to know for sure if to have the head removed and to test the springs.
As far as the carb hoses, it looks there there are two places
I plan on taking it to a Speed Shop on Wednesday for evaluation and convey all the ignition recommendations from this forum in additon to any finding regarding the carb hoses and anything else.
I could also look into the speed shop putting in an original Carter?
The Edelbrock carb is an aftermarket replacement for the original Carter AVS. its similar in appearance to the original Carter. Edelbrock bought the license from Carter when they went out of business. The aftermarket unit resembles the original but metering calibration is different; metering components are similar and some parts (jets and metering rods) can interchange. The Edelbrock part number is stamped on the mounting flange near the mounting bolt, behind the coil or on a stamped tag under one of the air horn screws. Research this number with Edelbrock to determine the CFM of your carb along with the metering rods and jets that were supplied compared to what is actually in the carb.
Someone installed an aftermarket electronic ignition conversion depending on who supplied the components, the control box (ECU) have been known to have intermittent issues and can fail without notice. Test and record the compression of each cylinder using the factory shop manual procedures. Its not likely that a head gasket has failed but possible...the shop manual explains.
Almost everyone over carburates (bigger than needed) in search of more power which results in poor performance. Its too bad that the original carb is MIA.... Again, just my opinion....
BOB RENTON
