wyrmrider
looks much better- that old stuff was scary
spend a lot of time setting up the new rockers and do your homework on the spacers b4 ordering pushrods
I've not used much crane rockers as Isky is a friend of mine- We used to do Wednesday lunch with Big John and Nick Arias unfortunately lots of the old timers are gone
Isky's had a hard pad and I never wore one like yours shown
Lots of variation on roller rockers- Cranes used to be a real funky design- to be polite IDK how they are now
Trick is to set up the valve side then check to see if the pushrod side is at least reasonable- not angled too much to not quite too much instead of equal angles open and closed- and do set up the rocker balls as high as you can get them
It's pretty obvious that most vendors use a "one design fits all" rocker body which does not have the right angle for a MOPAR if that turnsout to be the case return them
The link I sent vendor could also advise- getting his shims is much easier than making your own
