Fuel Injection and Front Fittings
So let's start with good progress. I still had to finish the connections with the fuel lines to my fuel injection tank. As stated in earlier posts, I used two stock 3/8" fuel lines and mounted them in the car. This picture shows how I started the day - the lines were just hanging there and not connected to the tank. Of course, I had marked the supply and return lines since I had hooked them up in the engine compartment.
Here is a picture after completion. To do this, I terminated each end of the steel 3/8" lines with AN6 female fittings. On the supply line I hooked in the Russel fuel filter. On the return line, I just hooked the line directly up to the tank. I hooked the fuel filter up, then custom cut and made the return line, and then finished up with the supply line. As each line was made, I connected the hard line to the body. You can see I still have a zip tie on the lines in this picture. Everything seems to fit well, and I don't believe there will be any rubbing or rattling problems. The tank has to drop one more time to hook up a vent line, the sender and fuel pump power. But good progress here!
(SIGH) So then let's move to the front suspension.
I received my replacement spindles from Right Stuff Detailing. I painted them up and set to work installing them. They have Left and Right markings on them, and the calipers mount on the rear on the 73 Road Runner. All the pictures show this too, but then again, I really didn't read the instructions because I know what I am doing, right? :iamwithstupid:
Well, I mounted them all up, including connecting the upper ball joint and torqueing them to 100 LB FT. Then I couldn't hook up the brake line, so I then went back to the instructions. Oh, if the line doesn't fit, you have to reverse the assemblies and switch them side to side. This will mount the calipers on the front of the wheel.
CRAP. I now don't know if I can now get these apart without damaging the upper ball joint or at least the rubber boot. Beating on a pickle fork is sure to cause some sort of problems.
I guess I will first try to get some other brake lines and see if I can make them fit well. Grrrrr
