I did some research and discovered that subwoofers work much better if they are in the trunk pointed towards the rear of the car. My original plan was to have mine under the back seat, so I decided to switch plans.
I made a metal panel designed to go between the back seat "V" brace. I had to weld two pieces of metal together (easy for many of you guys, but a big deal for me where I had to avoid warping it). I then painted the one side flat black and mounted the subwoofer to ensure it would fit in between the braces.
I then put Dynamat on the interior side.
Here it is installed in the car.
This picture is a bit fuzzy, but here it is with the trunk divider - this fits fine with no fitment issues.
Here is the subwoofer from inside the trunk. Since the panel was painted flat black, it pretty much matches the trunk divider panel and blends in. Hopefully the subwoofer will work well mounted here!
