Here are a couple of more detailed pictures of the issue. My concern is that this is with the suspension fully unloaded and hanging. As the suspension travels up, the line will kink hard.
Maybe try and put a bend on the hard line so it angles towards the center of the car instead of pointing backwards and up??? :shruggy:
Interesting. That looks like my setup. It just looks like the rubber line will take a beating having to make a couple of sharp u bends.
As far as trick parts, I figured rubber lines have worked great on these cars for many years. I guess I like the "stock" look as much as possible while trying to "hide" the trick parts... :grin:
not the best angle but you can see the the steel line section of the line is pointing up.
I was surprised to see with all of the other trick parts, you aren't installing steel braided brake lines?
