Bee1971
Sewing machine on steroids with my Comp XE285.
X2
XE 275HL
383/432 Stroker that I built
X2
XE 275HL
Followed the old Direct Connection valve adjustment decal. Start at TDC #1 firing and adjust one intake/one exhaust, rotate clockwise 45-degrees (I have degree tape on my harmonic balancer) & repeat.
At each 45-degree rotation, I loosened the appropriate adjustment nuts & backed off the screws. Then I rotated the pushrod with one hand, while I slowly turned the screw in, until I felt the pushrod seat in the lifter. Each time, I went in/out with the adjustment screw 3-4 times to be sure I had found the "zero pre-load", noted the direction of the adjustment screw, turned it in 3/4 turn & tightened the lock nut.
It was a little quieter, but it also lost 8hp compared to the HS rockers...... .
No sir, that is not what I did. I did thisAm I understanding you correctly when you say you put the engine on #1 TDC and adjusted #1 INT & EXH, then turned the engine 45* and adjusted #8, etc. through the firing order? If so, that's not correct. After #1, the crank should be turned 90*, not 45*. The cylinders fire 90* apart. Maybe I misunderstood you...
This is the method I've always used (solids or hydraulic) and worked 100% of the time for me. That being said, if you want peace of mind, maybe go back and pull the covers and try this. At least then you know it's not you.Try adjusting the valves using the EOIC method rather than the old Direction Connection method.
http://www.cpgnation.com/forum/threads/comp-cams-quick-tech-video-how-to-set-valve-lash.4986/
Kinda surprised it was only 8 hp
I've never done a comparison test between them. And I have not used a stamped rocker set on any of my stuff in 40 years. As a kid 40 years ago, simply looking at an adjustable verses the stamping I said, "there has to be some power in those ductile iron adjustables", and never looked back. Of course, I adjusted them to between 0.002" and 0.003" preload on hydraulics. Never tested that either, but just about anyone that seemed to know something back then did it that way.It’s funny you say that....... at the time of that test(about 20 years ago), I was thinking the difference would be less than that....... and was kinda surprised at the 8hp difference.
Thanks 65hemi, but that is basically what the Direct Connection chart does....making sure the valve you're adjusting is on the base circle of the cam. I am leaning towards pulling off one of the valve covers to check for "contact marks" from the rocker arms, just to be sure. I definitely had this problem with factory valve covers with baffles.Try adjusting the valves using the EOIC method rather than the old Direction Connection method.
Hey BSB67, how did you set the lifter pre-load like that? Did you use a dial indicator on the "nose" (valve side) of the rocker arm?I've never done a comparison test between them. And I have not used a stamped rocker set on any of my stuff in 40 years. As a kid 40 years ago, simply looking at an adjustable verses the stamping I said, "there has to be some power in those ductile iron adjustables", and never looked back. Of course, I adjusted them to between 0.002" and 0.003" preload on hydraulics. Never tested that either, but just about anyone that seemed to know something back then did that way.
I've just turned mine in 3/4 turn. I went an extra 1/4 turn to be SURE I wasn't leaving any lash in the valvetrain.
