dvw
Line to Line is local to me. I know plenty who have coated pistons with no issues. My sons new engine had coated pistons from them for the same reason.I purchased the intake gaskets that TrickFlow suggests. While I’m sure the superformance gaskets are superior to these FelPros, I’ll most likely just use them.
Great news, got a call from my machinist. Crank is done. Hone is done. He’s now moving on to balancing and mocking everything up before handing it back to me for assembly. Slight issue though….. He is not comfortable with the piston clearance he’s seeing after hone @ .007. I would agree that number is excessive and could cause ring seal issues and potential skirt issues from excessive piston rock. Called the guys at Line to Line piston coatings. They say they can hit any number I want within a tolerance of .0005. So I’m thinking the pistons will go the to them For .0025 coating, to land on .0045 clearance. Thoughts?
High Performance Race Engine Coatings | 248-625-3052 | Line2Line
Anybody here used this process in the past? If so, what was your results?
Doug
